Home > Td5 > Does disconnecting the ECU give problems? |
foz.in.oz Member Since: 31 Jul 2008 Location: Gladstone, QLD Posts: 64 |
You should not have any issues as long as you disconnect the battery first and wait for about a minute before disconnecting the ECU. Mine has been in an out of the car half a dozen times now.
Don't forget to check your radio code before disconnecting! Land Rovers are an addiction. Toyotas are for quitters. WWW.CQLROC.ORG |
18th Aug 2009 9:12pm |
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 |
Are you going raise up to cubby box or roof height ?, I saw a thread somewhere for wiring extension for TD5 if thats useful |
19th Aug 2009 12:20am |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
I know Devon 4x4 do an extention: http://www.devon4x4.com/products_a/p1755c2...nsion.html
As above, all you need to do is disconect the battery for a little while first. Glyn |
19th Aug 2009 9:30am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Thanks guys,
First I want to see how high I can get it in the Cubby box/ bulkhead direction. I don't know yet how I will want to have my roof yet. It's now a sheep farmer's pick-up with the Ifor Williams canopy on the back. I kind off like that as you don't see them this way in The Netherlands. On the otherside a hard top with windows is more practical but that is the standard here. I would like to drive it as a softtop in the summer but not in the winter. So I would like to have the ECU as high as possible but I don't know how high yet. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
19th Aug 2009 9:07pm |
Tatt Member Since: 04 Oct 2008 Location: Was Castleford, now Cape Town! Posts: 47 |
Found this on the PPcages website - looks like they did a pretty good job when they moved the ecu:
http://www.ppcages.com/index.php?Rollcage=seatbrackets Tom |
21st Aug 2009 9:27pm |
That's were I wanted to mount it too. The 90's color is correct too. I just don't like the seat holders. Roel
22nd Aug 2009 11:23am |
The one advantage of mounting it there is that there is little chance of the oil seeping down the loom getting into the ecu - it will probably just leave a puddle on the seatbox instead!
I intend moving mine to the same spot when I finally get rid of the centre seat. Tom |
22nd Aug 2009 1:20pm |
You can fit it there with the standard wireloom, you just need to extent the cables to the transfer box for the High/low sensor and the difflock sensor.
That project is almost finished just need a new ECU as mine has had swimming lessons and clearly didn't make it. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
7th Sep 2009 7:26pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8143 |
cubby box or similar height gets my vote, if its in the roof and you go over - its at lowest point then! Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
12th Nov 2009 5:56pm |
