Home > Td5 > MSB ECU Cruise Control Option
chinnus
2001 Defender 90 Td5 ST Coniston Green
Hi all, Has anyone managed to crack the cruise control on an MSB ECU? read somewhere that Pete at BAS was working on it but nothing more since?
Post #191169 5th Dec 2012 2:50pm
farmer giles
i think tim from mobilecentre has got a compatible unit.
i am very glad he helped with mine (puma version), just wish the roads were a bit clearer to enjoy it more!
Post #191174 5th Dec 2012 2:59pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
The CC that will work with a MSB ECU will cost much more than fitting a new ECU and wiring it up, as long as you dont have a discovery transfer gears, in which case you will have to have one of the expensive kits.
Pete.
Post #191195 5th Dec 2012 4:15pm
chinnus
apologies for digging up an old post, But i think I am correct in saying that 1999-2002 discoveries had cruise control as an option??
They would of also had MSB ecus.....
Was it this device that made cruise control on them possible?>? and if so can that be applied to a defender??
http://www.ebay.co.uk/itm/LAND-ROVER-DISCO...3a7dfc19e1
Post #214214 25th Feb 2013 5:32pm
tazmarkuk
England 2000 Defender 110 Td5 HT Chawton White
Cruise
Didn't Terrafirma do an aftermarket kit for the Defender?????
Post #214230 25th Feb 2013 6:16pm
