Home > Td5 > MSB ECU Cruise Control Option |
chinnus Member Since: 24 Aug 2012 Location: UK Posts: 119 |
Hi all, Has anyone managed to crack the cruise control on an MSB ECU? read somewhere that Pete at BAS was working on it but nothing more since?
Cheers |
5th Dec 2012 2:50pm |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 |
i think tim from mobilecentre has got a compatible unit.
i am very glad he helped with mine (puma version), just wish the roads were a bit clearer to enjoy it more! |
5th Dec 2012 2:59pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
The CC that will work with a MSB ECU will cost much more than fitting a new ECU and wiring it up, as long as you dont have a discovery transfer gears, in which case you will have to have one of the expensive kits.
Pete. |
5th Dec 2012 4:15pm |
apologies for digging up an old post, But i think I am correct in saying that 1999-2002 discoveries had cruise control as an option??
They would of also had MSB ecus..... Was it this device that made cruise control on them possible?>? and if so can that be applied to a defender?? http://www.ebay.co.uk/itm/LAND-ROVER-DISCO...3a7dfc19e1 |
25th Feb 2013 5:32pm |
tazmarkuk Member Since: 24 Jan 2012 Location: Birmingham Posts: 134 |
Didn't Terrafirma do an aftermarket kit for the Defender?????
25th Feb 2013 6:16pm |
