Home > Tdi > Wiring problems
RobKeay
Wiring problems
I've fitted a new loom to my 200tdi project. I can't get the dipped to work. Also the fuse blows when I try to make the wipers work. I've put a new stalk on and have disconnected the motor and fuse stil pops.
It's an autosparks loom and everything else is fine.
Any advice ???
Post #189096 27th Nov 2012 10:13pm
K9F
Without an insulation tester or ohmeter it is just a matter of continuing to disconnect the outputs first then the inputs wherever possible in the circuit continually replacing the fuses until they no longer blow to determine where the short circuit lies be it in one of the components (like the stalk itself) or the loom.
'Half split' fault finding method is also a good way of rapidly finding the cause.
http://wiki.answers.com/Q/What_is_the_half..._technique If you go through life with your head in the sand....all people will see is an ar5e!!
Post #189109 27th Nov 2012 10:48pm
do you have a dim-dip model ? have a look under the drivers side wing for the resistor
Post #189146 28th Nov 2012 7:18am
RobKeay
Cheers ill get fault finding just hope it's not the loom it's self.
I remember a resister when I took it to bits but its not there now, what does it do?
Post #189153 28th Nov 2012 7:44am
