![]() | Home > Maintenance & Modifications > Roof Rack (question for 110) |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
I cut up a bicycle innertube also.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17609 ![]() ![]() ![]() |
When I fitted my Patriot rack I did it single-handed (and it is seriously heavy). In order to protect the roof I put a folded blanket on the roof, then laid two long timbers lengthways on top and secured them with ratchet straps. The timbers were thick enough to ensure the rack feet were clear of the gutters when the rack was on the timber, and were long enough to stick out over the rear flap of my IW canopy.
Once the timbers were secure I rested the front end of the rack on the rear of the timbers, then lifted the rack and slid it forwards. Once in the right place the straps came off, then it was easy enough to raise each side in turn, slide out that timber, and position the feet in the gutter. |
LittleFoot Member Since: 25 Aug 2012 Location: east sussex Posts: 233 ![]() ![]() |
Thanks everyone for the advice - much appreciated!
