Home > Technical > Puma alarm reset code
jlprojects
Wales 2011 Defender 130 Puma 2.4 HCPU Keswick Green
does anyone know where I can find the alarm reset code. My spare key has a disk with a 4 digit number, is this the same number used for the reset code? John
Post #185632 16th Nov 2012 4:27pm
Lorryman100
Re: Puma alarm reset code
You should have got an EKS code when you got the defender which will bypass the immobiliser for one ignition cycle to get you home if the key fob has failed. If not the dealer can read it straight off the 10AS using their diagnostic tool, or if you have a Nanocom or MSV2 etc, you can do it yourself. The disc holds the key set number for your defenders lock set, you would quote that number to the LR parts department if you needed to order additional pre cut keys.
Post #185779 17th Nov 2012 10:22am
jlprojects
I gave the dealer my VIN and reg number this morning and got a reset code. Tried several times and it does not reset. Sods law my MSV is in the UK and I'm in Ireland. John
Post #185784 17th Nov 2012 10:37am
Lorryman100
Sounds as though they have either recorded the wrong code at build or it has been changed in the meantime. You may need to find a local independent to check the 10AS settings page to read the code stored. Have you changed any of the settings in the 10AS previously? Also does the interior light work when opening and closing the drivers door. Whistle
Post #185787 17th Nov 2012 10:41am
jlprojects
Interior light works when opening and closing the drivers door. I've had the 110 since new virtually, before that my brother had it so I'm sure no setting have been changed. I'll look around for a dealer, see if they will come out to it. John
Post #185790 17th Nov 2012 10:56am
Lorryman100
Thumbs Up
Post #185792 17th Nov 2012 11:04am
jlprojects
Well, no joy with the dealer (Singland Motors) Limerick until next week. John
Post #185795 17th Nov 2012 11:27am
jlprojects
sorted John
Post #185829 17th Nov 2012 2:45pm
jlprojects
Many thanks to Ian at IRB for his help in sorting out the issue with resetting my alarm. I can't thank him enough, other than continuing to support him by buying his excellent products. John
Post #185830 17th Nov 2012 2:48pm
