Home > Maintenance & Modifications > ACF-50
Page 2 of 2 <12
nikojo
What do you use to spray the ACF-50????
The plastic spray patter doesn't aerosolize it much.........just glops on.
Post #185400 15th Nov 2012 10:32pm
Have you got the pump bottle - if so I've found I need to pump about 10 times for each few sprays; and it will depressurise over time so needs pumping again next time I come to use it.
Much prefer it over an aerosol though even if it can seem like a faff at times. Thrown many a can away when it's out of propellant but still feels like it has quite a bit of product left.
Post #185763 17th Nov 2012 10:28am
Bobble
It also needs using very, very sparingly.
Post #185766 17th Nov 2012 10:31am
ericvv
When I had mine Dinitrolled by a first class pro this year, I know they did all 5 doors as well as the A- and B- posts with the waxy whitish transaparent Dinitrol stuff. A bit of dripping in the first week, but easy to wipe clean until that is over.... You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #185775 17th Nov 2012 10:51am
Page 2 of 2 <12
