Home > Td5 > SMOKING DEFENDER
tazmarkuk
England 2000 Defender 110 Td5 HT Chawton White
SMOKING DEFENDER
hi guys,
I need some advice as to what has happened to my Defender TD5 engine, the engine has started smoking this seems to be mainly white smoke, it starts fine and doesn't smoke, but as it starts to warm up it will smoke, I've not got any loss of power neither have the fluid levels changed, someone has mentioned to me it might be an oil seal on the exhaust side of the turbo, as the exhaust warms so does the oil hence the smoke, is there any way of checking this without having to get a replacement turbo.
It also seems to have a miss fire when you hold the revs at about 1500rpm and belches out loads of white smoke, there is no pressure in the cooling system or diesel in the oil, as soon you release the throtlle it stops, it will rev up with no missing but smokes.
the engine was perfectly fine before this, doesn't breath out of the rocker cover and has covered 75000 miles
Post #183310 8th Nov 2012 9:16pm
bob neville
Sorry to say that sounds exactly like the symptoms mine had before the turbo expired Shocked
Start it in the morning and there was blue/grey/white smoke. Seemed like it was running on 4 cylinders. Would clear but still puffing smoke on revving the engine.
Changed the injector seals, injector harness, MAF sensor, cleaned the MAP sensor and still happened.
Eventually the garage looked at the front of the turbo and they could see it was taking a few seconds for the turbo to start spooling when the engine was revved - and oil was then being forced into the engine.
Diagnosis on mine was oil seals and bearings shot.
New turbo has sorted it Thumbs Up
57k on mine and it is a 2001.
2013 Defender 90 CSW - sold
Post #183383 9th Nov 2012 8:37am
tazmarkuk
thanks Bob,
I’ve done the same Maf sensor, Injectors seals etc. hoping its the Turbo, but does not have any play, will look tomorrow to see if its spinning ok, I’m hoping then it’s a seal on the exhaust side as I’ve been told, your symptoms described do seem to be the same, fingers crossed, thanks again
Post #183485 9th Nov 2012 4:20pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
Should have popped down to us tonight, would have had a look... Putting Dreams on Drives at JLR Solihull..
Post #183643 9th Nov 2012 10:48pm
adseybear
Canada
keep us posted if you find the cause of this, mine does this misfire and chucks out white smoke when you hold the revs at about 1500 Sad 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration
2019 Jeep Wrangler JL Rubicon - SOLD
2006 Volvo V70 D5 - Ocean Race Edition, SOLD
2003 VW Passat Estate 1.9TDI - SOLD
2008 BMW 320D M Sport Estate - SOLD
2001 Defender 90 Td5 Hard Top - SOLD
Post #184601 13th Nov 2012 10:35am
