![]() | Home > Td5 > SMOKING DEFENDER |
Sorry to say that sounds exactly like the symptoms mine had before the turbo expired
![]() Start it in the morning and there was blue/grey/white smoke. Seemed like it was running on 4 cylinders. Would clear but still puffing smoke on revving the engine. Changed the injector seals, injector harness, MAF sensor, cleaned the MAP sensor and still happened. Eventually the garage looked at the front of the turbo and they could see it was taking a few seconds for the turbo to start spooling when the engine was revved - and oil was then being forced into the engine. Diagnosis on mine was oil seals and bearings shot. New turbo has sorted it ![]() 57k on mine and it is a 2001. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
tazmarkuk Member Since: 24 Jan 2012 Location: Birmingham Posts: 134 ![]() ![]() ![]() |
thanks Bob,
I’ve done the same Maf sensor, Injectors seals etc. hoping its the Turbo, but does not have any play, will look tomorrow to see if its spinning ok, I’m hoping then it’s a seal on the exhaust side as I’ve been told, your symptoms described do seem to be the same, fingers crossed, thanks again |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1385 ![]() ![]() ![]() |
Should have popped down to us tonight, would have had a look... Putting Dreams on Drives at JLR Solihull..
adseybear Member Since: 08 Oct 2009 Location: Vancouver, Canada Posts: 262 ![]() ![]() |
keep us posted if you find the cause of this, mine does this misfire and chucks out white smoke when you hold the revs at about 1500
![]() 1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration 2019 Jeep Wrangler JL Rubicon - SOLD 2006 Volvo V70 D5 - Ocean Race Edition, SOLD 2003 VW Passat Estate 1.9TDI - SOLD 2008 BMW 320D M Sport Estate - SOLD 2001 Defender 90 Td5 Hard Top - SOLD |
