- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
blackwolf wrote:It does however require 4 holes to be drilled in the RH of the windscreen frame for the brackets.
Just wondering if there is a way to fit without having to do this? Drilling the windscreen support seems a bit wrong to me.
I had a couple of Mantec snorkels fitted to Discos and whilst they were rigid, the only upper support they had was a small bolt through the rain gutter. Is this not possible on a Defender?
Alternatively, what about a right angle bracket "sikaflexed" to the windscreen support.
I noted from Brendan's Oz blog that the traditional method of fixing to the windscreen was a point of failure.
5th Nov 2012 7:48pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
