Home > Td5 > Manifold studs
Trossachs turbo
Scotland 2005 Defender 90 Td5 CSW Oslo Blue
Manifold studs
After remap,I have a broken lower stud,I note from the forum reference to "uprated studs". Has anyone any idea where I can obtain these
Post #181231 2nd Nov 2012 9:01am
landy andy
JE engineering do a stud and spacer kit as does IRB developments.
But I would say that you don't just have a broken stud, but you have a warped exhaust manifold.
If this is the case you need to get yours skimmed, then refitted with new studs. And don't be tempted to fit second hand or new manifold unless this has already warped and already been skimmed.
Andy
Post #181235 2nd Nov 2012 9:21am
Trossachs turbo
Thanks for the info,will strip and test with steel edge
Post #181239 2nd Nov 2012 9:42am
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
You might also want to consider partly grinding out the webs in between the manifold branches. I had exactly the same problem shortly after a remap, broken stud and warped manifold. I exchanged the old one for the modified version and have had no problems since then. According to my LR garage this is a common failure following a remap. He also claims he's had no failures of the modified manifolds. Time will tell but so far no issues.
Post #181295 2nd Nov 2012 12:56pm
wslr
Andy's right.
I've used the JE stud kits on several heavily mapped Td5's and none have ever come back with this issue when the JE kit has been used, and the manifold skimmed.
Post #181505 2nd Nov 2012 9:44pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
The IRB kit isn't strictly speaking a stud. Since having the original manifold skimmed and the IRB kit fitted I have had no problems. Have been running it with a lot more boost than standard and it has been fine.
Post #181630 3rd Nov 2012 11:12am
Trossachs turbo
Thanks for the advice,got the kit from JE,with difficulty extracted flush broken stud from rearmost hole,I called JE as they recommend re drilling manifold holes to 9.2to9.5mm,but this is a non standard drill size to acquire,so they explained that using a round file to elongate the holes in a fore and aft manner would suffice, as the heat expands the manifold in that plane,and this allows for the movement.Have now put back together and what a difference the remap now making sense.Many thanks to the guys at JE
Post #185072 14th Nov 2012 6:56pm
me@td5.org
Basically all of the kits are about allowing the manifold to move without breaking the studs or worse the head. Using longer studs allows greater movement without more elasticity.
For the drill try 3/8"
Post #185076 14th Nov 2012 7:05pm
