Home > Td5 > Repositioning TD5 oil filter?
MPN
Finland 2003 Defender 110 Td5 USW Belize Green
Hi,
As everyone must agree that it is in a ridiculous place...are there any ready made kits that allow relocating it into a more convenient location? If not, any DIY experiences then?
Cheers,
M
Post #179661 28th Oct 2012 8:13am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Mahle do a filter which is shorter and is much easier to fit.
Post #179691 28th Oct 2012 9:59am
I think you'd struggle get a remote filter kit in there more than just a filter. It does become easier, with experience. Thumbs Up
Post #179692 28th Oct 2012 10:01am
MPN
OK.
I suppose I need to live with it.
Still...it is in a really daft place!!
Post #179698 28th Oct 2012 10:12am
You're not wrong Thumbs Up
Post #179702 28th Oct 2012 10:13am
df1
Do you lads generally remove the turbo oil pipe to change the filter ?
Post #179733 28th Oct 2012 1:44pm
Nope Thumbs Up You can get at it quite easily, the filter goes back on at a funny angle. A guy over the road from me comes to me for hints and tips for spannering on his td5 disco. Only last weekend, after borrowing my oil drainer, he said that my best tip was "when you begin to lose your patience with something, pack your tools away nicely and go back in the house"
He did this after struggling with the filter, then he came back out after having a brew and just spun the filter on easily, first time!
Post #179739 28th Oct 2012 2:23pm
df1
Must have a bit of a fiddle with it next time round, I've been removing the oil pipe that goes from the turbo to the block for the last few years.
The heads on the 2 m6 bolts are starting to get a bit worn, same too with the 24mm fitting where it screws into the block, so I'll be trying with without removal next time.
Post #179744 28th Oct 2012 2:36pm
ibexman
I dont find it that difficult i use oil filter pliers
Post #179748 28th Oct 2012 2:46pm
It's the OC298 Mahle filter. This is made to LR standards, and like was said, is slightly shorter than some other aftermarket filters, and will fit in at an angle.
Post #179773 28th Oct 2012 3:49pm
df1
The reason I do it is to prevent oil spillage around the engine from the filter, you can basically take it out vertically.
It's not really the loosening thats my problem.
Post #179774 28th Oct 2012 3:50pm
geo.smc
Scotland 2006 Defender 90 Td5 XS CSW Zambezi Silver
It is a bit difficult but managable ,i can do it and i have hands like shovels,lol. if a hammer wont fix it,, then its electrical
Post #195800 22nd Dec 2012 8:22pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Put it in a carrier bag (one with no holes in it!) after you have loosened it but before you unscrew it all the way, any oil you drip will be in the bag and you just tie the bag up when its out and you have no mess at all.
Pete.
Post #195882 22nd Dec 2012 9:48pm
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
I use a TD5 oil filter spanner...
http://www.ebay.co.uk/itm/LAND-ROVER-TD5-O...35c2acd271
It makes life a bit easier and is the easiest way I have found to get it undone.
Jason.
Post #195885 22nd Dec 2012 9:54pm
jabber
United States 1986 Defender 110 Other SW Oslo Blue
Jason.
This doesn't fit the mahle filters though.
Post #199167 5th Jan 2013 12:41pm
