Home > My Defender > DarthFender TD5 110 |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6771 |
thanks, but there all in and working as of this morning I ended up not cutting any hole out at all, as I used to be a panel beater i decided to just hit it flat with a big hammer if I ever decide to change it back I can just knock it back into shape
20th Mar 2014 2:50pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Now there's a good idea
20th Mar 2014 3:07pm |
when i did mine in a 2003 110, scarey moment when you start cutting the wheel arch .. great idea Mk1
23rd Mar 2014 8:50am |
This weekend I've mostly been re-trimming, sound deadening and insulating the roof.
Mouldly, dirty headliner Click image to enlarge Cut re-trim fabric to size Fold in half and spray on contact adhesive Push and mould to contours Insulate Light backing before re-fitting to save fuses Fold over edges and glue and tape up Looking good so far, two more to go Silent Coat the roof (cheap Dynamat) Managed to pick a Military "NATO TUM" 110 HazMat kit The inside of the kit was then cut and used over the top of the sound deadening material Start to refit the trim Very happy |
30th Mar 2014 10:26pm |
looks great! I always look forward to seeing updates from you as most of the stuff you do seems to be what I'm planning for mine.
30th Mar 2014 11:23pm |
31st Mar 2014 7:46am |
Quick 30mins addition. Thanks to Myers for the extra light I now have a light in the middle of the 110 (why LR have never put one there is a mystery)
No light Masked up and carefully cut a hole, fished the wires that I'd left there for this job Installed to a Factory finish |
31st Mar 2014 5:31pm |
Tonight's little job was to add some soundproofing to the bonnet.
Quickly measured the sound in the cab at idle. 63.3db was about the average Then got to work on the kitchen table (Mrs Tiger was out) First step was Silent Coat (cheap Dynamat) to kill the vibrations and add a bit of mass Then Silent Coat Hoodliner Tape it all up nice and neat Put it back on the car and measure in exactly the same way Dropped 3.5db at idle, I'll know better tomorrow when I drive it if it feels quieter |
2nd Apr 2014 8:59pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
You could also stick 1cm thick felt to the underside of your bonnet,I used cable tie's as well for a bit more security.
http://www.frost.co.uk/sound-deadening-felt-sheets.html Pov.spec,ftw. 2006, 110,TD5. |
2nd Apr 2014 9:30pm |
Bit tight for space now.
Touches the coolant bottle lid |
2nd Apr 2014 9:40pm |
Next major project is the transmission tunnel as I reckon that's where most of the noise comes from.
2nd Apr 2014 9:41pm |
Well, drove it today and it's made a difference, not massive but 1 step closer to being nicer on long runs.
I think the transmission tunnel will make the biggest difference. |
3rd Apr 2014 10:12am |
Stage2 started
Click image to enlarge |
6th Apr 2014 10:03am |
I put sound deadening and closed cell foam across the whole floor bulkhead and transmission tunnel and then put the original trims and mats etc back (these were a bit tight) and it made quite a big difference. You've also given me another job as the extra light in the roof lining seems like a very good idea
6th Apr 2014 10:24am |
