Home > My Defender > DarthFender TD5 110
Page 8 of 16 <123 ... 789 ... 141516>
Tiger
Click on it to make it massive, but for reference the dimensions I used for the cut out on 110 to get puma seats in.
Measurements are
85mm From Inside Edge
20mm From Seatbelt trim (Outside Edge)
185mm From crease at base
The width of the opening in 90mm
The very top bit is 125mm in from the inside edge and allows a space for the 'Tilt' handle. I think If I were doing this again I would just make this the same width as the rest of the cut out.
Also mine are tight extra 5mm in each direction wouldn't hurt
Post #317507 20th Mar 2014 2:44pm
mk1collector
Thumbs Up thanks, but there all in and working as of this morning Mr. Green I ended up not cutting any hole out at all, as I used to be a panel beater i decided to just hit it flat with a big hammer Rolling with laughter if I ever decide to change it back I can just knock it back into shape Laughing
Post #317509 20th Mar 2014 2:50pm
Tiger
Now there's a good idea Bow down
Post #317511 20th Mar 2014 3:07pm
when i did mine in a 2003 110, scarey moment when you start cutting the wheel arch .. great idea Mk1 Thumbs Up
Post #318284 23rd Mar 2014 8:50am
Tiger
This weekend I've mostly been re-trimming, sound deadening and insulating the roof.
Mouldly, dirty headliner
Cut re-trim fabric to size
Fold in half and spray on contact adhesive
Push and mould to contours
Insulate Light backing before re-fitting to save fuses
Fold over edges and glue and tape up
Looking good so far, two more to go
Silent Coat the roof (cheap Dynamat)
Managed to pick a Military "NATO TUM" 110 HazMat kit
The inside of the kit was then cut and used over the top of the sound deadening material
Start to refit the trim
Very happy Thumbs Up
Post #320410 30th Mar 2014 10:26pm
mk1collector
Thumbs Up looks great! I always look forward to seeing updates from you as most of the stuff you do seems to be what I'm planning for mine.
Post #320418 30th Mar 2014 11:23pm
Tiger
Thumbs Up
Post #320438 31st Mar 2014 7:46am
Tiger
Quick 30mins addition. Thanks to Myers for the extra light I now have a light in the middle of the 110 (why LR have never put one there is a mystery)
No light
Masked up and carefully cut a hole, fished the wires that I'd left there for this job
Installed to a Factory finish
Post #320540 31st Mar 2014 5:31pm
Tiger
Tonight's little job was to add some soundproofing to the bonnet.
Quickly measured the sound in the cab at idle. 63.3db was about the average
Then got to work on the kitchen table Whistle (Mrs Tiger was out)
First step was Silent Coat (cheap Dynamat) to kill the vibrations and add a bit of mass
Then Silent Coat Hoodliner
Tape it all up nice and neat
Put it back on the car and measure in exactly the same way
Dropped 3.5db at idle, I'll know better tomorrow when I drive it if it feels quieter
Post #321151 2nd Apr 2014 8:59pm
jimbob7
You could also stick 1cm thick felt to the underside of your bonnet,I used cable tie's as well for a bit more security.
http://www.frost.co.uk/sound-deadening-felt-sheets.html Pov.spec,ftw. 2006, 110,TD5.
Post #321160 2nd Apr 2014 9:30pm
Tiger
Bit tight for space now.
Touches the coolant bottle lid Neutral
Post #321163 2nd Apr 2014 9:40pm
Tiger
Next major project is the transmission tunnel as I reckon that's where most of the noise comes from.
Post #321164 2nd Apr 2014 9:41pm
Tiger
Well, drove it today and it's made a difference, not massive but 1 step closer to being nicer on long runs.
I think the transmission tunnel will make the biggest difference.
Post #321223 3rd Apr 2014 10:12am
Tiger
Stage2 started
Post #321885 6th Apr 2014 10:03am
mk1collector
I put sound deadening and closed cell foam across the whole floor bulkhead and transmission tunnel and then put the original trims and mats etc back (these were a bit tight) and it made quite a big difference. You've also given me another job Big Cry as the extra light in the roof lining seems like a very good idea Thumbs Up
Post #321889 6th Apr 2014 10:24am
