Home > Technical > Sudden radio interference
ZeDefender
Help requested:
Turned on my radio this morning (LR Puma issue) and there was loads of crackling and interference. Still there tonight.
I haven't driven the 110 for a few days and the last thing I did was scrap the reverse park sensor. Only electrical connections were to the reversing lamp and I encased those cables (individually) in resin (where the insulation had been cut by the connectors).
The aerial is standard LR telescopic and I have checked it is screwed down and earthed. If I unplug the aerial cable to the radio, it goes quiet (no crackling).
The reversing lamp works fine (no short) and besides, if all lamps are off at the back how could its cables interfere?
Can a telescopic aerial "break" inside? Wobbling the antenna doesn't make it worse.
Any ideas, however bizarre, most welcome. I'm fresh out of them Sad
Ta very much,
Matt Tell someone you love them today because life is short.
Post #177187 19th Oct 2012 5:16pm
Maybe a chafed cable. See if yo can trace it. Easier said than done I know. $W33T $0U7H3RN $UG4R
Post #177193 19th Oct 2012 5:43pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Does the crackle change pitch at all with speed or load?
Post #177211 19th Oct 2012 6:08pm
ZeDefender
No... but I just took the radio out to check all the cabling again and hit (or rather "dropped") it a bit and now the crackling has stopped. Dry joint perhaps Rolling Eyes According to the label, the radio was made in Mexico in 2002.
I'm thinking another warranty issue Evil or Very Mad
Cheers guys
Post #177223 19th Oct 2012 6:45pm
Or get a new one under warranty then sell it for top price being brand new and then get an aftermarket one. Cool Kenwood cough cough Rolling with laughter
Perfect excuse. $W33T $0U7H3RN $UG4R
Post #177227 19th Oct 2012 6:48pm
ZeDefender
Life is cruel Rolling Eyes Tell someone you love them today because life is short.
Post #177228 19th Oct 2012 6:52pm
From another thread now it makes sense. I forgot you put the Kenwood in the other car. So you've just got the LR unit with aux in I guess $W33T $0U7H3RN $UG4R
Post #177261 19th Oct 2012 8:10pm
AndyS
My one crackles when the air-con is on, could it be that, something you've switched on?
Post #177265 19th Oct 2012 8:17pm
ZeDefender
Aux works fine Laughing Tell someone you love them today because life is short.
Post #177274 19th Oct 2012 8:34pm
ZeDefender
Don't think so - I've fiddled with everything. Wife thought I'd lost my marbles when I asked her to listen to the radio and put the car in reverse whilst I crawled under the rear mudflap Shocked Tell someone you love them today because life is short.
Post #177276 19th Oct 2012 8:36pm
kmac
Do you have another radio you can plug into the Defender so you can eliminate the radio as the cause? I had this in the wife's Golf and assumed it was the radio itself. Changed that and problem persisted but after a while it cleared itself so I'm none the wiser, other than knowing at least it wasn't the radio unit itself that was causing the issue.
The other thing you can then do is disconnect the aerial at the retractable aerial end and radio end and run another cable from the radio to the aerial - that will eliminate another section.
Post #177314 19th Oct 2012 9:55pm
ZeDefender
Both good ideas I will try tomorrow - need to savage wifey's car again for the Kenwood HU (useful in so many ways Laughing) and find the spare aerial coax cable (will probably have to botch the connector) I have somewhere in the boiler room... Tell someone you love them today because life is short.
Post #177319 19th Oct 2012 10:18pm
spudfan
Ireland
Radio interference? Usually caused by the wife talking. Rolling with laughter 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #177326 19th Oct 2012 10:48pm
Captain Speaking
2008 Defender 90 Puma 2.4 CSW Tonga Green
Me too! I just accept it now!
Post #207002 30th Jan 2013 10:46pm
re: the dry joints - when my parrot died (going back to them for an autopsy) i dug out my land rover radio/cd, fitted but it was not great, I ended up taking the covers off and having a look, there were a few joints with no solder at all Shocked - I soldered them and the radio if 100% now.
Post #207025 31st Jan 2013 7:13am
