Home > Tdi > Cooking oil ? |
Psulli16 Member Since: 04 Oct 2012 Location: Coventry Posts: 87 |
What's people thoughts on cooking oil ??? WWW.1STOVERLAND.CO.UK
http://www.facebook.com/#!/1stOverland |
4th Oct 2012 5:28pm |
Great for making nice chips Darren
4th Oct 2012 5:35pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3641 |
my son has run his 200tdi none turbo S3 on use veg oil for a while with no apparent ill effects and now intermittently runs his 200tdi disco on new veg oil its just a bit smelly and smokes more than on diesel. loads of people use it all the time but the best bet is twin tanks one for diesel for starting and for a few mins before stopping and one for veg for when the engine is nice and warm, pre heaters are a good idea as well as the veg oil goes thick in cold weather. DEFENDER 90 TDCI XS,
4th Oct 2012 5:38pm |
I've been n cooking oil for a year now, it's been fine, 50% mix with derv. Just started to add 1 litre of petrol to take out the lumpiness. WWW.1STOVERLAND.CO.UK
4th Oct 2012 5:48pm |
I know what you mean, 100% cooking oil is just to thick.. If you mix a small bottle up and leave it on your door step then you will know what it's like in the morning. The issue seems to be viscosity. TD5 is a different story. Not sure I'd venture that far. WWW.1STOVERLAND.CO.UK
4th Oct 2012 5:56pm |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 |
Been using new veg oil for years. In the summer Ive had the mixture as high as 70/30 veg oil/derv. As the temperatures drop over winter I reduce the amount of veg oil, when its really cold I dont use it at all. It thickens in cold weather and can make it difficult for the engine to start.
I just part fill the tank with derv, then when I get home I pour in the veg oil. Infact now Ive got myself a nice new driveway I now pour the veg oil in whilst parked at work, don't want any spils on my drive In all the years Ive been using it my 300tdi hasn't suffered any negative effects/faults at all. It runs exactly the same with oil or without it, same mpg, same performance. Just smells a bit thats all. |
5th Oct 2012 2:04am |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
I was tempted to try this a little................ But veg oil is twice as expensive as fuel out here!!!
Oh well, Glyn |
5th Oct 2012 4:41am |
If I had an old pre common rail engine Id use a mix based on temperature as per War Pig. I wont be risking it in a common rail and nearly new vehicle. Need to get an cheap TDCI Mondeo as a test mule DEFENDER 90 TDCI XS,
5th Oct 2012 4:57am |
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 |
my 300tdi has run on svo/dino mix for over 3 years now. svo=£1 ltr. its not for everyone, somepeople never do anything 'out of the ordinary'.
15th Oct 2012 5:28pm |
I ran mine on 100% oil last week with some petrol to thin it,,,,, mixed results, it ran great but starting was a pain !!!! i think for the winter months ill be running 50% oil 50% Derv. However on long runs IE wales for weekends away ill run 100% oil for the run down as I always take Jerry cans of both oil and derv. WWW.1STOVERLAND.CO.UK
14th Nov 2012 10:38am |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
glyn - forget the cost...think of the environment !
I don't believe veg oil has any detrimental effect on rubber seals, bio diesel with methanol residue is another story. rgards leaving the oil on your door step and it going thick ....you need to have a look at they type of cooling as different oil solidify at different temperatures. I believe rapeseed oil is best and palm oils worst - but thats something you can experiment with......and let me know |
14th Nov 2012 12:46pm |
personally I wouldn't even run mine a 50% this time of year. max 30% svo I'd rcommend.
15th Nov 2012 5:49pm |
