Home > Wheels & Tyres > Winter tyres...
Page 5 of 6 <123456>
BigWheels
ZeDefender wrote:
Sorry I don't know the answer. I was going to harp on about false economy and safety... then I read this:
http://www.aandrtire.com/abouttechnotires.htm
I also did some reading about safety. Quality remoulds seem to be as safe (or unsafe) as any other tyre. They are not the re-treads of 30 years ago. It has made me think Thumbs Up
I use retreads (Craddock's Security 6.5 x 16) on my Series 2. If I want more modern, I'd go for th Insa Turbo Traction Track http://www.camskill.co.uk/m64b1634s234p595..._TL_/RS_GB Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #174414 9th Oct 2012 5:38pm
The topic of the thread is "winter tyres" - in simple terms:
Winter tyres have a soft compound and work better when the temperature drops below 7C.
Snow tyres have a snow flake printed on them, these are made using the softer compound.
When I first bought snow tyres (legal requirement in Switzerland) I was skeptical about the difference, the tyre centre had a great way to describe the difference ...
You have a 1p on your right index finger, an eraser on your left index finger, you push then along a kitchen worktop, the difference in resistance is the difference in grip.
Post #174465 9th Oct 2012 7:20pm
AT2's have the snowflake symbol on them Thumbs Up Darren
Post #174469 9th Oct 2012 7:30pm
are they winter compound ? from what I have read, they have the north American Snow symbol that means they are ok on ice but i can't find anything stating they are the winter compound
Post #174471 9th Oct 2012 7:35pm
I didn't realise that there was any difference, to be honest. They certainly work well in snow. Darren
Post #174476 9th Oct 2012 7:47pm
ericvv
Steve, that is not all quite correct. Seems there is a lot of confusion here. See remarks below in Italic...
[quote="bpman"]The topic of the thread is "winter tyres" - in simple terms:
That is correct, (softer compound usually with more silicone content). The below 7° argument probably is correct too, but also comes in handy as advertisement argument
Not quite correct. The snow flake on the mountain is the accepted and registered mark for a winter tire. A "snow" tire is a not well defined concept, often used in various ways by different tire manufacturers. The best available description is by Continental in following link.
http://www.conti-online.com/generator/www/...gs_en.html
This is not correct, snow tires are not a term used by lawmakers anywhere as it is not a clearly defined concept, wintertires are a clearly defined concept with the snow flake on the mountain the official mark, but they are not mandatory at all in Switzerland. The only thing that is mandatory is when you go to the mountains and if there is sufficient snow, the local authorities may put signs up that chains are mandatory to go beyond a certain point. This is then law (and usually controlled by police) irrespective if you have summer, winter, or snow M+S tires on.  You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #174502 9th Oct 2012 8:35pm
agreed Eric, they are not mandatory in CH, but if you have an accident the insurance company may not payout if you are not using winter tyres.
My ice defender came with M&S marked tyres but these were not made of soft compound but Philippe was happy to tell me that I did not have to change the tyres (even though I did).
Markings and tread patterns aside, from a safety point of view, when driving on packed ice / snow surfaces, soft compound / winter tyres are much safer than all season tyres whether they are AT, MT or whatever - that is the point I was trying to make.
the link does indeed have a great definition of tyre markings Thumbs Up
Post #174508 9th Oct 2012 8:45pm
ericvv
The person quoted by you there, earlier this spring when I was about to take the SVX to Belgium for Dinitrolling, still told me that he did not understand my logic of doing this, because Defenders these days (including mine, and yours too) are standard built on a galvanized chassis, yes? Shocked Rolling Eyes Rolling with laughter
As your M+S are the same OEM Grabbers as mine, which winter tires did you change for at the time you were here in Switzerland? The Nokians which are offered here by LR as a accessory, or other? Would like to hear if there are different real winter tires in 235/85-16, because at the time I did some research and did not find much or anything in that size. And, do you like them in the winter, makes any difference?
Anyway I'm very pleased with my Nokians on modulars for the winter, actually Autobritt will put them on next week thursday at the same time as they will install the content of the boxes which arrived yesterday from Mobilecentre Whistle Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
Post #174534 10th Oct 2012 3:46am
Glynparry25
Why are people still using Winter and Snow together.Other than the fact it snows in winter, when it comes to tires they are comletly opposite.
Snow is like a a sand/ mud combination, this is why mud terrain/ All terrain tires get the M+S classification- they dig into the powder and carve their way through creating traction.
Compacted snow and ice is just slippy. This is why you need a proper winter tire- as mentioned it is a compound that sticks much better than normal tires.
Go on youtube and put in 'Winter tire tests' and you will get an endless list of tests in different countries by different people. But note that ALL the tests by profesional companies/ auto mags are on either compacted snow or ice..... they aren't bothered about testing in fresh powder (A lot in the US/ Canada even use their local ice rink).
90-95% of the people around the world drive on a road, so why would a company develop a tire for 5% of the people for only 30-50% of the year- the reserch would WAY out price the profit from sales. Because of this you will never have a Snow and winter tire combined............... But on that day snow chain companies will be bricking it!!
Glyn Dog Sheep
Post #174535 10th Oct 2012 4:22am
ericvv
Glyn, fully agree Thumbs Up Want to see the first person standing up here who in a winter is frequently driving on fresh non compacted snow Whistle
And.... snow chain companies will not be bricking me, the day that it really snows, my snow chains (4 of them of course) will be readily available in the back of the Defender Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
Post #174536 10th Oct 2012 4:31am
Eric I bought cooper discoverer M+S, recommended by a Norwegian friend of mine, Nokians also very very good in the cold / snow / ice ... whatever Very Happy
Yes, the salesman also told me they were galvanized Rolling with laughter
video ... http://www.youtube.com/watch?v=JGfvyPtYR0Y
Post #174543 10th Oct 2012 6:14am
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
Some good info on this thread Cool
Never really get that badder winters in zummerzet but you never know, my GG's have the Marks & Spencer logo and they have worked alright for me past, adjusting your driving style to suit helps most Wink Its mainly the other road users that are my concern Rolling Eyes 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #174758 11th Oct 2012 5:28am
Glynparry25
When I was working in Yorkshire I was regularly driving across the pennies, only about 30% of the roads get cleared and th rest are left to drift over- I always took these routes because they were less likely to be blocked by regular car drivers. And for fun I snowboard on the freshest powder I can find which tends to push me towards driving off the beaten track to find these routes.
Now in Cyprus.... they don't have a road clearing service other than for the main roads around Troodos so whenever going up there it is always fun to take a few back roads Thumbs Up
It was this trip that persuaded me to buy chains- 5Km of drifts, and nearly through to the other side just to be stopped about 1Km sort because of a larger drift on a slight incline................So much effort, so little reward Sad
This is how the truck looks on regular winters:
I miss the Alps........ Driving them next year though so all is good Thumbs Up
Glyn Dog :sheep:
Post #174764 11th Oct 2012 6:18am
ZeDefender
Hopefully to simplify - this is what our local Munich (very competent) tyre dealer/fitter explained to me:
Summer tyres are made of a harder compound to improve wear and reduce noise. The tread pattern is also designed accordingly, and also to reduce the possibility of aquaplaning at high speeds. They require no marking.
Winter (that includes some "all-rounder") tyres are principally designed for slippery surfaces that you will find on roads (not "off-piste"), e.g. ice and compacted snow. Consequently they should be made of softer compound to grip under these conditions and their tread designed to dissipate more water/slush (e.g. with siping). They do not wear as well as Summer tyres (especially when the temperatures increase) and are usually quite noisy on dry roads. Winter tyres/wheels should be narrow so they cut through snow/slush etc. hopefully to find grip underneath.
Here's the important bit: it is law here to have the correct tyre for the weather conditions - that is the only requirement. Whilst you can use winter tyres in summer (although braking distance can increase and the compound hardens over summer) you cannot (legally or for insurance) use summer tyres if the conditions (even just frost) require winter ones. Generally, the marking M+S means you are okay, although, as I mentioned before, tyre manufacturers (especially asian) can put it on anything (their discretion) because it is not a protected trademark. However, the newer "snowflake" symbol is protected and designates that the tyre is entirely suitable for winter and snow. It is a softer compound and has deeper treads for ice, compacted and non-compacted snow. If you use it you are 100% legal (in winter, at least), unless there is "Kettenpflicht" - snowchain requirement.
"Snow tyres", unlike the snowflake symbol, is not a defined, protected or legal term and they need have no marking at all... if you don't drive on-road! Otherwise, for road use, the previous rules apply and you can choose whatever tread pattern you think will get you through "the white devil" as they call it here Thumbs Up
So in winter conditions, if you use a narrow M+S tyre from a reputable manufacturer, with a soft compound and decent tread (frequently looks more "car-like" than what we usually associate with Defenders) you should have no problems from a safety or legal aspect. If you want to be 100% certain, buy snowflake tyres (various treads according use) which are approved for all winter conditions. "Winter" here (for tyres) is generally considered to be October to Easter, i.e. 1/2 the year Big Cry
Finally, as I found out last winter, no tyre can replace good driving in poor conditions. Driving downhill on slush over ice is really bad news whatever boots you're wearing Shocked
Hope that might help.
p.s. Didn't stop me just buying the cheapest M+S tyres for the A2 though, as it's only used in emergencies Embarassed Tell someone you love them today because life is short.
Post #174782 11th Oct 2012 8:02am
Glyn, totally OT (so my apologies) but may I ask where you got your rock sliders? They look to be just what I am after!
Thanks.
Post #174787 11th Oct 2012 8:32am
