Home > Maintenance & Modifications > Entreqs Aluminium Bumper
Lorryman100
I got the new bumper a couple of months ago, and I am very pleased with the build, looks and the thick powder coating. The Puma has been abused lately what with being in the sea and through gorse and heather plus the farm work ending up with the resulting paint scratches along the Pumas body, however the bumper and steering guard show no signs of damage and seem to deflect stone chips with ease! The bumper is a straight swap for the piece of crap LR fit as standard and comes with stainless fittings plus both plastic and delric isolators to stop galvanic corrosion between the Aluminium, Stainless steel and the chassis rail steel. First job was to remove the radiator grill to expose the 4 mounting bolts holding the original bumper in place, once these were removed the old bumper was removed. The Entreq bumper does not have the securing nuts fitted to the bottom of the bumper as the OEM one does, instead you are supplied with two plates which go underneath the Entreq bumper to secure the mounting bolts. This then when tightened squeezes the bumper onto the chassis rails giving a very secure clamp fit. The fitting kit consists of 4 x stainless bolts, 4x plastic collars, 6 x delric flat spacers and a tube of copperslip. I offered up the bumper to the chassis rails and placed one of the flat spacers between the bumper and chassis rail, I then slid in one of the mounting bolts with a plastic collar fitted, this collar is the exact size for the holes cut into the top of the bumper. The next part was tricky, I needed to place a spacer on the inside of the bumper were it meets the chassis rail then another between the bumper and the bottom mounting plate, and the holes need to match up to get the bolt through and into the mounting plate. I tried doing it by aligning the holes and then dropping both bolts in, but this was not a good idea as everything kept moving. So in the end I just aligned everything for one bolt and once that bit into the mounting plate I just teased all the spacers so that the second bolt went in and bit. Leaving the side I just did loose, I then went on and repeated the process for the other side. Once all 4 bolts where in it was just a case of lining the bumper up with the wings and tightening the bolts. Once it was where I wanted it I undone 1 bolt at a time and covered it and the threads in Duralac. Once that as done it was just a case of refitting the radiator grill and the number plate. I did not want to drill the bumper to mount the plate so just used the double sided plate tape and the number plate has not moved since.
The bumper was easy to fit once you sussed out how to line everything up so the mounting bolts went through everything. I am thoroughly delighted with Entreqs bumper and think it looks the DB's on my Puma, especially with the Entreq steering guard also fitted. Once again Entreq has excelled in my opinion on design, build and quality of their products, and I am one very happy and delighted customer. IMHO, you get a thoroughly well designed and finished product from Entreq that is well worth the price tag. Thumbs Up Very Happy Bow down
The bumper is available here:
http://www.entreq.de/products/protection/bumpers.html
The steering guard here:
http://www.entreq.de/products/protection/unterfahrschutz.html
PS, I also have a set of these on order (present from the wife) Whistle Twisted Evil
http://www.entreq.de/products/performance/airflow.html
Brian.
Post #167395 10th Sep 2012 3:39pm
MartinK
Wow, that bumper does look really good (as it should for that price Shocked ). But you pay for quality as they say Thumbs Up
Worth considering when the current (original) one get's tatty.
Thanks for sharing Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #167396 10th Sep 2012 3:46pm
K9F
Entreq do indeed make fantastic gear. Thumbs Up I have some of it fitted to my Defender. At nearly £714 for the bumper I would expect nothing else but Rolls Royce quality and from your experience it looks like you got just that! It does look great too! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #167420 10th Sep 2012 4:34pm
Killer90
Site Sponsor
Shocked Shocked very good quality, love all there bits really Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #167426 10th Sep 2012 4:44pm
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
Very smart. Love all that internal bracing. Almost worth hanging it back to front so it can be seen.
Post #167449 10th Sep 2012 5:44pm
Lorryman100
Thumbs Up
Like K9F I have the odd bit of Entreq gear on and in my Puma. Whistle But this is a hefty piece of metal/artwork, 5-6mm thick aluminium with internal reinforcement to stop any kinking, and with louvres on the bottom plus the bracing metalwork has holes in to allow the removal of mud etc. It is very well designed and a solid bit of kit unlike the OEM one that needed changing every 6 months due to the rust. So I'm betting this bumper will last the lifetime of my Puma, bar any accidents that is. Whistle
Post #167455 10th Sep 2012 6:06pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Shame Entreq don't make defenders really, not that we would be able to afford them mind.
Looks good with the guard Thumbs Up
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #167482 10th Sep 2012 7:48pm
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
looks good, nice and subtle
Post #167507 10th Sep 2012 8:45pm
but would you put a high lift under one end to change a tyre or lift it out of a set of ruts? Whistle
Post #177796 21st Oct 2012 7:50pm
Sorry, i think defender bumpers should be "square"; tapered ends and rounded edges make it look like a Santana PS10 Sad Sad
Post #177800 21st Oct 2012 8:02pm
df1
Agree, not gone on it at all, although I'm sure the build quality is excellent, pity they don't have one the same shape as original.
Post #177812 21st Oct 2012 8:33pm
Lorryman100
Everyone is entitled to their own opinion Thumbs Up
I personally love it, which is just as well considering it is fitted to my Puma. Whistle Mr. Green
Don't own a hilift jack as IMHO they are too unstable Thumbs Up I do however have airbag jacks should the need arise.
Post #178656 24th Oct 2012 4:26pm
d j hutton
Correct me if I'm wrong but I believe there are some round jacking points under those rectangular rubber bits on the front of the chassis, and you can get a hi lift adaptor so you could use them, rather than the bumper (not sure a standard LR bumper would take the weight, although I may be wrong there)
Nice looking bumper, looking forward to the next add on Thumbs Up
Buy British 🇬🇧
Post #178720 24th Oct 2012 7:25pm
Lorryman100
Cheers DJ Thumbs Up There are holes under those rubber covers on each chassis rail, though fitting the Entreq steering guards recovery points, would restrict the depth of any hilift attachment due to the location of one of the mounting bolts.
Post #178750 24th Oct 2012 8:01pm
leeds
Entreq gear is top, top quality Thumbs Up
Design and aesthetitics can be a matter of personal opinion.
Personally, I prefer tapered bumpers which sits on top of the chassis legs as it gives much better approach angle. Especially if it is winch equipped. Yes it does leave the front bottom corner of the wings vunerable to damage.
Having seen the quality of the Entreq bumper, I can confirm it is top quality. Olaf at Entreq certainly pays close attention to detail. Yes it is a premium product and that sort of quality will not come cheap.
So if you want the best top quality equipment to fit to your Defender then Entreq sets the standard for top quality equipment.
Brendan
Post #178762 24th Oct 2012 8:25pm
