![]() | Home > Maintenance & Modifications > Entreqs Aluminium Bumper |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
I got the new bumper a couple of months ago, and I am very pleased with the build, looks and the thick powder coating. The Puma has been abused lately what with being in the sea and through gorse and heather plus the farm work ending up with the resulting paint scratches along the Pumas body, however the bumper and steering guard show no signs of damage and seem to deflect stone chips with ease! The bumper is a straight swap for the piece of crap LR fit as standard and comes with stainless fittings plus both plastic and delric isolators to stop galvanic corrosion between the Aluminium, Stainless steel and the chassis rail steel. First job was to remove the radiator grill to expose the 4 mounting bolts holding the original bumper in place, once these were removed the old bumper was removed. The Entreq bumper does not have the securing nuts fitted to the bottom of the bumper as the OEM one does, instead you are supplied with two plates which go underneath the Entreq bumper to secure the mounting bolts. This then when tightened squeezes the bumper onto the chassis rails giving a very secure clamp fit. The fitting kit consists of 4 x stainless bolts, 4x plastic collars, 6 x delric flat spacers and a tube of copperslip. I offered up the bumper to the chassis rails and placed one of the flat spacers between the bumper and chassis rail, I then slid in one of the mounting bolts with a plastic collar fitted, this collar is the exact size for the holes cut into the top of the bumper. The next part was tricky, I needed to place a spacer on the inside of the bumper were it meets the chassis rail then another between the bumper and the bottom mounting plate, and the holes need to match up to get the bolt through and into the mounting plate. I tried doing it by aligning the holes and then dropping both bolts in, but this was not a good idea as everything kept moving. So in the end I just aligned everything for one bolt and once that bit into the mounting plate I just teased all the spacers so that the second bolt went in and bit. Leaving the side I just did loose, I then went on and repeated the process for the other side. Once all 4 bolts where in it was just a case of lining the bumper up with the wings and tightening the bolts. Once it was where I wanted it I undone 1 bolt at a time and covered it and the threads in Duralac. Once that as done it was just a case of refitting the radiator grill and the number plate. I did not want to drill the bumper to mount the plate so just used the double sided plate tape and the number plate has not moved since.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge The bumper was easy to fit once you sussed out how to line everything up so the mounting bolts went through everything. I am thoroughly delighted with Entreqs bumper and think it looks the DB's on my Puma, especially with the Entreq steering guard also fitted. Once again Entreq has excelled in my opinion on design, build and quality of their products, and I am one very happy and delighted customer. IMHO, you get a thoroughly well designed and finished product from Entreq that is well worth the price tag. ![]() ![]() ![]() The bumper is available here: http://www.entreq.de/products/protection/bumpers.html The steering guard here: http://www.entreq.de/products/protection/unterfahrschutz.html PS, I also have a set of these on order (present from the wife) ![]() ![]() http://www.entreq.de/products/performance/airflow.html Brian. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Wow, that bumper does look really good (as it should for that price
![]() ![]() Worth considering when the current (original) one get's tatty. Thanks for sharing ![]() |
Entreq do indeed make fantastic gear.
![]() Treat every day as if it is your last....one day you will be right!! |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
![]() ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 ![]() ![]() ![]() |
Very smart. Love all that internal bracing. Almost worth hanging it back to front so it can be seen.
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Shame Entreq don't make defenders really, not that we would be able to afford them mind.
Looks good with the guard ![]() DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 ![]() ![]() ![]() |
looks good, nice and subtle
but would you put a high lift under one end to change a tyre or lift it out of a set of ruts?
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6168 ![]() ![]() ![]() |
Sorry, i think defender bumpers should be "square"; tapered ends and rounded edges make it look like a Santana PS10
df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 ![]() |
Agree, not gone on it at all, although I'm sure the build quality is excellent, pity they don't have one the same shape as original. |
Everyone is entitled to their own opinion
![]() I personally love it, which is just as well considering it is fitted to my Puma. ![]() ![]()
Don't own a hilift jack as IMHO they are too unstable ![]() |
Correct me if I'm wrong but I believe there are some round jacking points under those rectangular rubber bits on the front of the chassis, and you can get a hi lift adaptor so you could use them, rather than the bumper (not sure a standard LR bumper would take the weight, although I may be wrong there)
Nice looking bumper, looking forward to the next add on ![]() DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
Cheers DJ
![]() ![]() Click image to enlarge |
Entreq gear is top, top quality
![]() Design and aesthetitics can be a matter of personal opinion. Personally, I prefer tapered bumpers which sits on top of the chassis legs as it gives much better approach angle. Especially if it is winch equipped. Yes it does leave the front bottom corner of the wings vunerable to damage. Having seen the quality of the Entreq bumper, I can confirm it is top quality. Olaf at Entreq certainly pays close attention to detail. Yes it is a premium product and that sort of quality will not come cheap. So if you want the best top quality equipment to fit to your Defender then Entreq sets the standard for top quality equipment. Brendan |
