Home > Maintenance & Modifications > Best suspension set up for overlander 130? |
drive4change Member Since: 15 Aug 2012 Location: Somerset Posts: 193 |
Hi All,
Would like to invite any advice on what the best suspension package to go for would be for a defender 130 overland vehicle. I want to keep it as easy to repair as possible so dont want anything extremely technical. Scouring through the various sites i see a lot of packages for 90 and 110 but not much at all for 130. Any help would be greatly appreciated. Thanks Steve |
1st Sep 2012 3:02pm |
Overlanding - what's wrong with a standard suspension setup? i thought all 130s had HD suspension.
I'd be looking at upgrading driveshafts, CVs and possibly lockers especially as your truck could be fully laden. |
1st Sep 2012 4:27pm |
markalpha Member Since: 23 Apr 2008 Location: Downham Market Posts: 690 |
Done 3 weeks around Portugal this year with stock suspense on my 130.. Front was fine but rear did sag abit and shock at rear didn't cope too well when weather got hot.
I may just change the shocks. |
1st Sep 2012 5:51pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5724 |
I would recommend land rover hd springs and Koni dampers for the nicest ride, but if you need a bit more fine tuning in the spring department would go across to OME springs.
Andy |
1st Sep 2012 6:41pm |
I was looking at Koni, OME or Terrafirma big bore shocks.
Glad to hear Koni are good, which ones do you have?. |
1st Sep 2012 6:49pm |
I've had all three.
Start with list in reverse Terrafirma, are , poor quality, poor service, badly designed, and fail........ OME, is what i am running at the mo, this is because I require the extra travel shocks that they can supply and that I would rely on in an overland situation, also have the advantage that they are same damper on all corners, and is a Land Crusier part, so is source able. Koni, Probably the best damper for standard or a plus 2". I managed to hit massive rock taking out two wheels, one was touching the brake disc, and dampers took all this abuse. I would recommend as fit and forget. Top quality. Andy |
1st Sep 2012 7:55pm |
Thanks for the info Andy
1st Sep 2012 8:11pm |
sense of adventure Member Since: 11 Nov 2011 Location: warwickshire Posts: 147 |
Only change the fronts if you have a winch, standard springs all round and Koni heavy track raid shocks all round, you will need nothing else
1st Sep 2012 8:40pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
OME 754's and a set of these baby's
Click image to enlarge[/quote] 130's have feeling's as well you know |
2nd Sep 2012 12:51pm |
Hi Andrew.
Is that what you are running? Steve |
2nd Sep 2012 4:14pm |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 |
These beauties arrived today for my 130
Click image to enlarge 993 Varioram - Guards Red Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
6th Sep 2012 6:46pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2642 |
what kind of price are we looking at for a set?
6th Sep 2012 7:20pm |
£136.00 EACH 993 Varioram - Guards Red
6th Sep 2012 7:33pm |
SGH what model are the Koni shocks?.
Seems a good price where did you get them?. |
7th Sep 2012 7:06am |
