![]() | Home > Puma (Tdci) > Help! What to do? |
johnnyturbo2002 Member Since: 21 May 2009 Location: Poniente Granadino Posts: 371 ![]() ![]() ![]() |
So, yesterday the wife informs me that the light switch finally bit the dust. I was hoping it would last till October when I have the extended warranty checkup...but I guess today is action day. So, I would like to hard wire the light so when the ignition is on, the lights are on. (we always have them on anyway, so it seems the logical and simplest thing to do). My quesiton to all of you who are more in the know than me is: Can I just junp the fuses? if so , which ones, and if not, What should I be doing? Any help is greatly, greatly appreciated!!!!
Thanks John 2008 Defender 110 60 year Edition (sold unfortunately) IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX π 2.5crdi |
I can't tell you which specific wires to connect off-hand, but you're going to need a relay that's triggered by an ignition live. This will, essentially, replace the existing manual switch. Darren
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 ![]() ![]() ![]() |
Are you sure about that - a number of motorbikes have permanently wired on headlamps these days? John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Volvo's used to and probably still do always have their lights on...Motorbikes should have them on just so others can see them more readily. Thanks for your reply, I will try to get it sorted this afternoon... 2008 Defender 110 60 year Edition (sold unfortunately) IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX π 2.5crdi |
hi JT,
i concur with the others, get a new switch and if you have the time and inclination, wire in a couple of relays for the dip beam and full beam. if you still need an ignition "on" live, then of you have an heated screen, then there's an option, or take it from the alternator. when you remove the switch you will notice they are made from cheese, (well a soft plastic) and when they get warm they melt, this is why 100w bulbs are not recommended unless you add relays into the circuit. LED headlights draw significantly less current compared to halogens (if you need a reasoning tool for the wife) and they have dropped in price recently. good luck! steve |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 ![]() ![]() ![]() |
Hi John,
Surely if you bodge/hardwire the lights on this will invalidate your extended warranty anyway? Plus if you were going to wait until October to get it done, then get it done now under warranty, 2 months isn't going to make much difference! Trust me on this, if they can find any little way of getting out of a warranty work they will and bodging your headlight switch is a definite get out of jail free card for the warranty company! DON'T RISK IT!!!! Regards, Mark |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17704 ![]() ![]() ![]() |
Two situations when it is (as far as I know and it certainly used to be) unlawful to have your headlights on:-
1) when reversing 2) when stationary other than in stationary traffic (i.e., you've pulled up at the side of the road). Motorcycles don't reverse, so 1) is not relevant. Volvos and other cars with daytime running lights do not use the obligatory dip beam for this purpose, hence not relevant. I have however never, ever heard of anyone actually being done for either of these and the plice themselves are amongst the worst offenders - round here they always seem to have main beam headlights on if stationary at an incident at night thus making life very difficult for passing traffic. They have no exemption from this. |
thanks fo rthe info to all,
getting it sorted tomorrow morning with a local garage that specializes in Defenders...the reason for the "wait till October" is that the dealer that I bought it from is about an hour and a half away, so I usually wait until I have some time off to do a drop and sort for a few days. (It basically came down to a less expensive truck in Germany than an outrageously expensive truck in Switzerland...) SO, thanks again for the help. great bunch of guys on here! 2008 Defender 110 60 year Edition (sold unfortunately) IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX π 2.5crdi |
guess I was referring to the daytime running lights that are almost the same as the low beam headlamps. (?) thyanks for clarifying JT 2008 Defender 110 60 year Edition (sold unfortunately) IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX π 2.5crdi |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
interesting post. i drive with my dips on and it is now automatic for me to switch them on as i finish turning the key and as you can't really turn the key off with the lights on it acts as a reminder
i also use the headlight leveler to drop the lights a bit in day time to minimize risk of glare for other drivers. i also carry a spare switch..............just in case. so far no problems at all. once the warranty is over i do plan to add a live feed and a relay for dip and beam. did someone say it's OK to take a live feed from the alternator - i thought you should always take the feed from the battery? BM52 |
Feed from the alternator if you want an Ignition switched feed.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
I ordered some bits from VWP, so I can plug a lead into the existing headlamp socket, that switches a relay (low current) that then feeds the bulbs from a dedicated hi-amp feed from the battery... Really simple to do, not expensive, and will let you got to stupidly high wattage bulbs to melt the reflectors, and retains the existing switchery... 80/130 watt bulbs with Crystals really do light up the road! ... ,-------,
.. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
Shax - i would be very interested in the parts you used. BM52
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20719 ![]() ![]() |
Shax - I don't believe that wattage is legal though
![]() β½οΈπ’οΈβοΈπ§°πͺ |
