Home > Puma (Tdci) > Help! What to do?
Page 2 of 2 <12
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
bm52 wrote:
Shax - i would be very interested in the parts you used.
2 x H4 plugs and terminals to get the low current switched feed for the relays.
2 x H4 sockets for the headlight hi current feed.
I used 4 x 40A relays and fused relay sockets, 2 per side, so low beam and high beam get a dedicated relay and fuse.
All relays are switched from the standard lighting switch, which needs NO MODS or direct wiring, and only use a few ma, so zero load on the switch.
The bulbs are fed from an 8AWG fused feed from the battery.
LOADS of wire!!!
So many fuses, so little time to find the blown Censored .. !!!! Nah, simple to find the dead ones when they go as all circuits have a fused feed. ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #165241 29th Aug 2012 11:50pm
Shax
custom90steve wrote:
Shax - I don't believe that wattage is legal though Confused
Quick to change the bulbs, not quite so quick to replace a melted headlight stalk in the arse-end of nowhere...
I drive with legal bulbs, but sometimes extra wattage is needed... Nuff sed! ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #165244 30th Aug 2012 12:04am
Shax
LOADS of wire!!!
Here's a quick lashup of the schematic of the mod...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #165293 30th Aug 2012 11:02am
Page 2 of 2 <12
