Home > Td5 > New master Cylinder has started to leak again :idea:
dorstsmith2
United Kingdom 2003 Defender 90 Td5 HT Caledonian Blue
Sad Have replace clutch master and slave cylinder as the old master Cylinder has started to leak, two later New master Cylinder has started to leak again Idea
The pedal is 140mm from the floor with no mats to the bottom of the pedal. and drive ok
Post #164516 26th Aug 2012 2:58pm
dorstsmith2
replace clutch master is britpart
Post #164535 26th Aug 2012 4:37pm
bob neville
I think you have answered your own question.
I would complain and get a refund. Then get a genuine or non s*****t one.
I was putting the rear eyebrows on the 90 yesterday and got some Britpart retainers, my thoughts were they can't get these wrong ? Wrong, they had a smaller diameter than the genuine ones. I ended up just using the pins to replace the ones I had lost, at least they fitted the OEM studs Thumbs Up
2013 Defender 90 CSW - sold
Post #164538 26th Aug 2012 5:12pm
And there lies your answer. Laughing Laughing
Post #164541 26th Aug 2012 5:17pm
Killer90
Site Sponsor
Bob
there spat clips are horrid arnt they, i found its best to tap the center pin through first otherwise trying to do it under the motor holding the arch they just smash Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #164543 26th Aug 2012 5:20pm
dorstsmith2
(Lucas Girling or genuine clutch master ?
Post #164612 26th Aug 2012 8:31pm
Killer90
Site Sponsor
lucas will be fine alot cheaper than genuine and up to the same quality Thumbs Up CSK Automotive
Post #164619 26th Aug 2012 8:54pm
Eduardo
I replace my leaking main cylinder by 2 Lucas-Girling: both starting to leak 2 days before change it. Finally I use the original and not problems since.
Cheers Eduardo
Post #164646 26th Aug 2012 10:16pm
Andrew DefenderBits
United Kingdom 2003 Defender 110 Td5 HT Alpine White
I have a selection of clutch master cylinders and the TRW ones are better quality than gen LR in my opinion, if anyone wants to pop in I'll show you both and you can see the difference in the quality of the castings. I don't sell Britpart! I also have the clips from Allmakes for a couple of quid or so for a pack of 10 so not sure that getting the really cheap ones is ever worth it!
Post #164690 27th Aug 2012 10:28am
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Hello,
Sorry to hear you put all that work in and it's no good, I have just had to do mine. Both slave and master cylinder. I would have been cross because mine was really awkward to fit being LHD. Give Defenderbits a call (site sponser) brilliant price for a Lucas master cylinder.
Steve
Edit: see above post...good prices and fast typer too Smile
Edit again: not Lucas but TRW ! Good quality
Post #164691 27th Aug 2012 10:29am
dorstsmith2
This will make laugh an other Britpart master cylinder in post to day and not a word from the suppler ? Rolling with laughter
Post #165370 30th Aug 2012 3:53pm
wslr
Not Paddocks is it?
Post #165597 31st Aug 2012 3:43pm
dorstsmith2
no more north than that Laughing
Post #165618 31st Aug 2012 5:30pm
kevb
Andrew DefenderBits wrote:
I don't sell Britpart!!
Such a simple statement, makes me want to do business with you! Very Happy
Post #165728 1st Sep 2012 11:07am
