Home > Td5 > New master Cylinder has started to leak again :idea: |
dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188 |
replace clutch master is britpart
26th Aug 2012 4:37pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
I think you have answered your own question.
I would complain and get a refund. Then get a genuine or non s*****t one. I was putting the rear eyebrows on the 90 yesterday and got some Britpart retainers, my thoughts were they can't get these wrong ? Wrong, they had a smaller diameter than the genuine ones. I ended up just using the pins to replace the ones I had lost, at least they fitted the OEM studs Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
26th Aug 2012 5:12pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6112 |
And there lies your answer. |
26th Aug 2012 5:17pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
there spat clips are horrid arnt they, i found its best to tap the center pin through first otherwise trying to do it under the motor holding the arch they just smash CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
26th Aug 2012 5:20pm |
(Lucas Girling or genuine clutch master ?
26th Aug 2012 8:31pm |
lucas will be fine alot cheaper than genuine and up to the same quality CSK Automotive
26th Aug 2012 8:54pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 |
I replace my leaking main cylinder by 2 Lucas-Girling: both starting to leak 2 days before change it. Finally I use the original and not problems since.
Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
26th Aug 2012 10:16pm |
Andrew DefenderBits Member Since: 15 May 2012 Location: Somerset Posts: 43 |
I have a selection of clutch master cylinders and the TRW ones are better quality than gen LR in my opinion, if anyone wants to pop in I'll show you both and you can see the difference in the quality of the castings. I don't sell Britpart! I also have the clips from Allmakes for a couple of quid or so for a pack of 10 so not sure that getting the really cheap ones is ever worth it!
27th Aug 2012 10:28am |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 587 |
Hello,
Sorry to hear you put all that work in and it's no good, I have just had to do mine. Both slave and master cylinder. I would have been cross because mine was really awkward to fit being LHD. Give Defenderbits a call (site sponser) brilliant price for a Lucas master cylinder. Steve Edit: see above post...good prices and fast typer too Edit again: not Lucas but TRW ! Good quality |
27th Aug 2012 10:29am |
This will make laugh an other Britpart master cylinder in post to day and not a word from the suppler ?
30th Aug 2012 3:53pm |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
Not Paddocks is it?
31st Aug 2012 3:43pm |
no more north than that
31st Aug 2012 5:30pm |
kevb Member Since: 03 Apr 2012 Location: AllPackedUp Posts: 34 |
Such a simple statement, makes me want to do business with you! |
1st Sep 2012 11:07am |
