- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
T1G UP
i think on a td5 it shuts the flow off to the matrix.so yes you could tap in before hand. The heat these things pump out it will do the engine and a couple of heaters easily. there 5 kw which is quite alot.
im gonna fit one of these under the rear seat http://www.ebay.co.uk/itm/New-Blown-Air-Wa...4abbc0db82 that way with the thermo top on it will heat everything
11th Sep 2012 2:24pm |
