Home > Maintenance & Modifications > Leaking rear side windows |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
could you get some close up pics posted up, could be getting in around the top part or even were the two pieces of glass meet stand there with a hose and try different parts youll know when it leaks and then atleast you know were its coming in from two man job though one inside and one with the hose CSK Automotive
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
14th Aug 2012 8:38pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5873 |
I can do when it rains next or tomorrow, which ever is sooner., A bit late to grab the hose and give the car a wash!
I get a feeling its were the two windows meet up. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
14th Aug 2012 8:43pm |
may need a new felt for it MWC7652 thats the part number for it CSK Automotive
14th Aug 2012 9:02pm |
The felt in the bottom corner has fallen apart... 1999 Defender TD5 110
14th Aug 2012 9:10pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2677 |
Do you ever use them?
Back when I had a truck cab years ago I just sealed the sliding window shut with silicone in the end, as the rattle was annoying me and I never opened the damn thing. When I come to put my 110 back together I'm just going to replace those rear windows with solid glass, can't see any reason to have them open unless you have passengers back there. |
14th Aug 2012 9:51pm |
They do get used but not very often. Mainly when I am on rallies when parked up and its too windy to open the door windows or when I have mast up and need the wire into the vehichle. 1999 Defender TD5 110
15th Aug 2012 7:05am |
pumaxs Member Since: 18 Jul 2012 Location: Bath Posts: 180 |
As said by others, a rattling sliding pane is probably down to knackered felt channels - You'll have fun replacing those!
As far as the leaks are concerned, and at risk of stating the obvious, are the drainage slots in the window frame blocked up with cr@p and causing water to overflow into the vehicle? Is the vertical rubber seal that should be located between fixed and sliding window panes damaged or missing? Pictures would help with diagnosis. '57 Defender 110 XS Station Wagon 2.4tdci |
15th Aug 2012 2:48pm |
I might have to investigate the felt option at some point
As far as I can tell the vertical rubber seals are correct and OK, Will post a picture. The drain holes look OK to me. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
15th Aug 2012 9:24pm |
Here is a picture of the leak
Click image to enlarge I noticed that the side panel was also wet and a closer look revealed that if I pressed the panel below the section where the bolts are, I get some water flexed/pumped out the joint. Click image to enlarge The leak is the same on the windows on the other side of the car but could not see any water escape from the same joint Both panels have been left off incase of more rain overnight and I will have another look. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
15th Aug 2012 9:34pm |
Here is a picture of the side window seal
Click image to enlarge 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
16th Aug 2012 12:33pm |
barjout Member Since: 09 Dec 2010 Location: Ottawa Canada Posts: 16 |
Good day.
Mine used to rattdle as well and they are now fixed. Instead of using the original felt I went toward the window channel option. http://www.woolies-trim.co.uk/c-290-single-track.aspx. In order to fix the rattle I had to take them off the vehicle. The screw that old the bar in the middle of the window with the rubber seal is what fix the rattle. It got loose with time. You can tight the bottom and top screw to the point that you wont be able to slide the windows anymore. Since they were apart I got them tinted. Now they look good and don't rattle. As for your leak you need to fix the roof leak first but when you take them apart you will see a silicone bead at the lower part of the middle metal bar. This might need to be renew!! |
20th Aug 2012 3:28pm |
Right back to leaking windows......
Over the weekend I ran some Sikaflex around the outside of the sliding windows where the frame meets the body in the hope of fixing the leak....But no. Click image to enlarge The water can be seen dripping from between the raised section of metal and the metal that forms the frame of the window as shown in the picture. So....Ideas on sealing this section of body? I was wondering if the water is getting past the roof and body seal? Ideas people please, I am getting fed up with wet carpets 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
30th Sep 2012 8:44pm |
hi Retro do you know anyone selling the single side glass as a kit or will it be bespoke ? |
1st Oct 2012 6:27am |
qwert Member Since: 26 Aug 2010 Location: Switzerland Posts: 33 |
Hi. It is an old thread but I see that you are still active. Were you able to fix the leak? Thanks. |
22nd Sep 2020 2:51pm |
