Home > Maintenance & Modifications > Wheel Spacers (again) Pics Please
Page 2 of 2 <12
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
When I fitted mine I didn't use copper grease or a torque wrench, I just tightened them "tight" but not stupid tight, I had them on my 90 for 4-5yrs without any issues, I forgot all about them to be honest and when I removed them they came of easily. As previously stated the natural rotation helps, never heard of any coming off Rolling Eyes . But if you are worried then maybe torque wrench should be used Whistle Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #204066 21st Jan 2013 8:52pm
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
A torque wrench is probably worth the investment anyway - the wheel nuts should be torqued-up anyway. I bought a very good wrench from MachineMart for about £20.
The spacers should be the same torque setting as the wheel nuts, 130Nm (96 ft lbs).
Check out this post for more details of when I fitted mine: http://www.defender2.net/forum/topic17318....el+spacers
Post #204074 21st Jan 2013 8:59pm
T5bnc wrote:
Fair enough although i thought that the natural rotation of the wheel naturally tightens the wheel nuts? does this not apply when spacers are envoled?
The rotation of the wheel does nothing whatsoever to keep the wheelnuts secure on a Landrover! If it did, the NS nuts would keep working loose.
Most commercials have LH threads on the NS in the vain hope that rotation helps but still lose nuts (and wheels) if the torque is not checked regularly.
The only thing that stops the nuts from coming loose is that they are properly tightened, and overtightening is as dangerous as undertightening.
Post #204080 21st Jan 2013 9:09pm
Page 2 of 2 <12
