Home > Tdi > Worthwhile maintenance jobs?
WarPig
Ive had my 1996 300tdi for about 7 yrs and I always change the oils, lubricants & filters on a regular basis. But incase im missing anything out, what other jobs would you say are worth doing from time to time to keep things in order. ie injectors etc?
Post #160911 9th Aug 2012 10:06am
I went through a similar process with a 300tdi Discovery a few years ago that I'd owned for five years. It ran well and had been meticulously serviced, but had covered over 140k miles. I was using it for overland trips and wanted to maintain reliability by carrying out 'preventative maintenance'. After umm-ing and ah-ing about how far to go, I settled on replacing all of the hoses, the fuel lift pump and the water pump, which are all relatively cheap. I also cleaned the intercooler with paraffin, which was very worthwhile.
I reasoned that most other things were either unlikely to fail catastrophically, i.e. you get some warning before they do, or we're just too expensive to replace 'just in case' such as the injection pump.
On a Defender, regular maintenance should also include cleaning the teat on the heater intake duct Smile Darren
Post #160989 9th Aug 2012 6:47pm
jst
grease anything with a grease nipple too, TRE, UJs Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #160999 9th Aug 2012 7:45pm
Dave-H
And see here .....
http://www.defender2.net/forum/topic14048.html
Wink Guns and Landrovers .... anything else is irrelevant.
Post #161004 9th Aug 2012 8:28pm
