Home > Tdi > Which coolant?
WarPig
Which coolant?
Id need to top up my coolant, are there any brands/types that folk here like to use?
Post #159585 2nd Aug 2012 11:16pm
Retroanaconda
I use whatever is in the shed at work, it's pretty much all the same.
Any ethelene glycol based stuff (the blue type) as per the workshop manual will be fine for a Tdi. Think the Td5s (and presumably Tdcis) use the pink OAT stuff.
Think my last batch was JCB stuff!
Post #159804 3rd Aug 2012 10:48pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
I tend to use comma:
http://www.commaoil.com/
Post #160774 8th Aug 2012 5:10pm
TR51
France 2014 Defender 110 Puma 2.2 SW Corris Grey
As Retroanaconda said they are pretty much the same, although you shouldn't mix the colors as they react together...
get a pipette if your not sure which yours has in it to be safe...
Post #160776 8th Aug 2012 5:24pm
Have a look at Opie Oils. Site sponsor and also happy to answer any questions. Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #160778 8th Aug 2012 5:41pm
WarPig
Well im sure I had green coolant but after noticing it was very low I topped it up with the only coolant I had, which was blue Shocked Should I drain it down?
I really need to find the reason why it was so low in the first place, I did notice a small puddle of coolant on the drive under my defender!
Just sent him a PM Thumbs Up
Post #160808 8th Aug 2012 7:30pm
wslr
The Tdi uses the standard blue coolant you can get from any autofactor.
Post #160838 8th Aug 2012 9:25pm
TR51
I think the 'green' colour would have actually been the blue one... The pink is very obviously red but the blue can look grey/blue/greenish Thumbs Up
Post #160842 8th Aug 2012 9:39pm
WarPig
wslrfrom a wrote:
The Tdi uses the standard blue coolant you can get ny autofactor.
Excellent, thanks Thumbs Up
Post #160849 8th Aug 2012 9:59pm
