Home > Maintenance & Modifications > Blown Engine
iandup77
2008 Defender 110 Puma 2.4 SW Zambezi Silver
Blown Engine
Hi all. Hope someone can give some clarity. My Defender burned two pistons only 60 000km on the clock. I suspected bad fuel quality because I used the vehicle in Zambia and Tanzania. Others told me it was because the engine was tuned. I am suspecting it was because of a leak on the air intake manifold.Had to drive about 5000km with the leak pulling a trailer and fully loaded roof rack. Can this be the real cause of the engine failure?? Really want to tune the new motor again but am a bit scared. Thanks. On a quite night in Africa you can hear the sound of rusting Land Cruisers
Post #157421 23rd Jul 2012 10:01am
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
Which engine? My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #157424 23rd Jul 2012 10:48am
iandup77
Was a 2.4 Puma motor. Year model 2008 On a quite night in Africa you can hear the sound of rusting Land Cruisers
Post #157425 23rd Jul 2012 10:53am
ZeDefender
Depends rather on who tuned it/what they did, doesn't it?
Was it a tuning box or a proper remap from a reputable company? Tell someone you love them today because life is short.
Post #157445 23rd Jul 2012 1:27pm
Sounds like an ideal time to slip in a 3.2l 5 cyl engine.... Cool Cool
Post #157447 23rd Jul 2012 1:28pm
dgardel
Italy
it is important! very important!!!
Please tell us more details about the tuned (who, when, which) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #157457 23rd Jul 2012 2:07pm
Naks
Re: Blown Engine
iandup77 wrote:
I am suspecting it was because of a leak on the air intake manifold.Had to drive about 5000km with the leak pulling a trailer and fully loaded roof rack..
Hmm, I don't see how a leak in the air intake manifold would cause and engine to implode - if anything the ECU would have reduced power to save the engine.
I'm tending towards fuel leak into the cylinders - yours would not be the first Puma to which this has happened. --
Post #157460 23rd Jul 2012 2:16pm
dgardel
Italy
Re: Blown Engine
Only a gasoline engine can have problems with air leak from inlet manifold (lean combustion = detonation).
In a comon rail diesel engine the problems can be generate from:
1. dripping injectors
2. incorrect injection timing
3. overtemperature for incorrect fuelling Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #157466 23rd Jul 2012 2:41pm
bell-auto-services
It could have be caused by many causes, water in fuel, bad fuel, over temp working it hard (though not likley if the sensors are correct) I dont think tuning would have a lot to do with it unless it was tuned to the hilt and you have works it to death.
Pete
Post #157526 23rd Jul 2012 7:07pm
bell-auto-services
Good idea Smile
My 2.2 engine is nearly out ready for a 3.2 and it runs perfect at only 12 miles and 19 days from build lol Smile
https://twitter.com/bellautos/status/227479001520816128/photo/1
Post #157527 23rd Jul 2012 7:08pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
my truck has been tuned since being 12 months old and personally i would say its tuned to its limit with a bigger turbo and all and i have had no issue so i wouldnt put it down to tuning
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #157531 23rd Jul 2012 7:28pm
ZeDefender
I think it's how it's "tuned" that might be the issue. I tried a tuning box once and I swear if I'd kept using it, something would have blown up Shocked
That being said, I guess a bad tun(ing box) would be noticeable from the outset... Tell someone you love them today because life is short.
Post #157533 23rd Jul 2012 7:33pm
iandup77
Hi All thanks for the feedback.
@dgardel I had a re map from a reliable company in SA that is strongly recommended by a 4x4 Forum.This map was done in Jan 2009. Then change to a piggy back system in Oct 2011 when I arrived back in SA. The company who installed this is Steves Auto Clinic also a well known company in SA. Two weeks later the motor went thus I am suspecting their product and a lot of people complain about their product. Thus make it difficult to pinpoint which product might have caused the problem.
@naks the vehicle did smoke a lot uphill but thought this was due to bad fuel I had to buy in Malawi. The temp gauge also went up all of a sudden and loss of power this happened about three times. What is the cause of fuel leaking into the cylinder?Because Bosch tested the injectors before I pulled the engine out.
@Pete yes many things could have caused the engine failure. But I am a bit skeptical about the the tuning quality in the South African market. I spoke to Naks and he is very happy with your product as well as many members on this forum.Might give you a call once my mind is made up.
Thanks On a quite night in Africa you can hear the sound of rusting Land Cruisers
Post #157591 24th Jul 2012 12:33am
big steve
why did you change to a piggyback unit if you had already had it tuned properly ?
Post #157592 24th Jul 2012 1:53am
wslr
From experience, not sure how the fuel is in TZ, but there was cases of fuel contamination in Kenya when the fuel was 'watered down' with kerosene. The newer imported Jap vehicles suffered from engine failures due to this.
Perhaps a combination of fuel and tuning?
Post #157608 24th Jul 2012 6:48am
