Home > Puma (Tdci) > Whistle why don't you!!
Morts
2008 Defender 90 Puma 2.4 CSW Tonga Green
Hi,
Ok I've got a 2008 Puma with 40k on it, I've just changed all the oils < really easy with a garden spray pump, thanks for the tip. Nw there is a faint whistle from the turbo, i used all land rover parts. It starts at about 1500 and goes to 2000. It sounds like a emergency vehicle a few hundred yards back. Bloody annoying!! I can't see I've changed anything, it definitely wasn't there before and doesn't sound like there is a mechanical brake down. I re checked the air filter and thats all sound and I've taken the heat shield of the turbo and there is nothing amiss, certainly no soot.
Any ideas or similar experiences would be good
Morts
Post #155494 14th Jul 2012 5:13am
ericvv
Post #155495 14th Jul 2012 5:19am
Glynparry25
Is it quite faint?
If so that is completely normal. I had the same before. Every time I put about half throttle on at low revs I would check my rear view mirror to see if something was approaching........ passengers also heard the sound.
Glyn Dog Sheep
Post #155499 14th Jul 2012 6:19am
wslr
If it is a screech noise, at those revs it could be the turbo to exhaust manifold gasket leaking. Mine did it twice then stopped after a de-cat.
Post #155506 14th Jul 2012 8:37am
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
whistling after service
In my experience, once after a service, the air filter box lid was not closed sufficiently well to create a seal - hence the noise (whistling) during acceleration.
It is a 'pain' to ensure the air filter box is sealed at the back - suggest double check this by removing the lid and replace again.
El pepe flamenco Embarassed JLS
'El Pepe Flamenco'
Post #155544 14th Jul 2012 2:39pm
Nick T
England 2010 Defender 90 Puma 2.4 HT Galway Green
Slightly off topic, but if the airbox lid wasn't making a tight seal on a TD5 would that cause it to be sluggish on acceleration at times?
Post #155584 14th Jul 2012 5:18pm
Lorryman100
Have a read of this post as I had something similar. Thumbs Up
http://www.aulro.com/afvb/90-110-130-defen...turbo.html
Post #155734 15th Jul 2012 3:10pm
T1G UP
Mine whistles like a banshee Whistle It's called boost!
Post #155735 15th Jul 2012 3:12pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I used to have a Meriva VXR.. Only 1.6 turbo, but SCREAMED on full chat.. Admittedly it was 237BHP (141 MPH GPS'ed), and on serious overboost, but I kinda liked hearing it when surprising the chavs in their "not so hot" hatches! Twisted Evil
Only rarely hear my Puma whistle, and only when the windows are down! ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #156054 16th Jul 2012 10:15pm
