Home > Puma (Tdci) > Whistle why don't you!! |
Probably a split turbo hose. Gives a whooshing or wistling sounds, without real loss of power. I had the same a year ago. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
14th Jul 2012 5:19am |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
Is it quite faint?
If so that is completely normal. I had the same before. Every time I put about half throttle on at low revs I would check my rear view mirror to see if something was approaching........ passengers also heard the sound. Glyn |
14th Jul 2012 6:19am |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
If it is a screech noise, at those revs it could be the turbo to exhaust manifold gasket leaking. Mine did it twice then stopped after a de-cat.
14th Jul 2012 8:37am |
jlerra Member Since: 10 Jul 2009 Location: Gibraltar/London Posts: 149 |
In my experience, once after a service, the air filter box lid was not closed sufficiently well to create a seal - hence the noise (whistling) during acceleration.
It is a 'pain' to ensure the air filter box is sealed at the back - suggest double check this by removing the lid and replace again. El pepe flamenco JLS 'El Pepe Flamenco' |
14th Jul 2012 2:39pm |
Nick T Member Since: 29 May 2011 Location: Bolton Posts: 203 |
Slightly off topic, but if the airbox lid wasn't making a tight seal on a TD5 would that cause it to be sluggish on acceleration at times?
14th Jul 2012 5:18pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Have a read of this post as I had something similar.
http://www.aulro.com/afvb/90-110-130-defen...turbo.html |
15th Jul 2012 3:10pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
Mine whistles like a banshee It's called boost!
15th Jul 2012 3:12pm |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 |
I used to have a Meriva VXR.. Only 1.6 turbo, but SCREAMED on full chat.. Admittedly it was 237BHP (141 MPH GPS'ed), and on serious overboost, but I kinda liked hearing it when surprising the chavs in their "not so hot" hatches!
Only rarely hear my Puma whistle, and only when the windows are down! ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
16th Jul 2012 10:15pm |
