Home > Puma (Tdci) > 2007 2.4 Defender Stalling no power |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
Fuel quantity sensor/Valve on the back of the diesel pump? Otherwise, EGR or other fuel issue.
12th Jul 2012 10:27am |
Doesn't really help in your circumstance but it would be well-worth the investment in a Scangauge, or another diagnostic tool...The scangauge would pay for itself first time you have any issues! EGR would be a guess as they are notoriously problematic and can cause all sorts of running issues.
There may be another Wiltshire forum member that may be able to assist perhaps? Do you have MIL (engine management) light illuminated? Quick call to dealer otherwise. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 12th Jul 2012 10:47am. Edited 1 time in total |
12th Jul 2012 10:40am |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6276 |
real long shot this.....don't suppose its got EEG in the registration has it?
I had a blue 110 which headed off to your part of the world. it had various problems which included silicone on the wiring loom connectors and various other issues. after my recent problems my first point of call for something like this would be to check all the fuses are in place / haven't blown (easy job and if nothing else rules this out). good luck. |
12th Jul 2012 10:43am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5574 |
Hello and welcome, glad you found us, and hope we can help you with our problem.
Andy |
12th Jul 2012 11:10am |
standard_Man Member Since: 12 Jul 2012 Location: Wiltshire Posts: 8 |
Not that one (Thankfully)
12th Jul 2012 11:18am |
Nugget Member Since: 25 Apr 2012 Location: Perth Posts: 8 |
I had what sounds like a similar problem a couple of years back on my 2008 2.4.
Cruising down the freeway, packed to the gunnels with family, dog and camping gear and the engine just quit. Engine would start but would quit again once you built up the rev’s. Checked fuses, fuel and all usual suspects, nothing. Tow truck job back to the dealer under warranty. I spent a bit of time with the work shop foreman when I went to pick the vehicle up after the repairs to get the low down on the fault. Being a mechanic I felt a bit stupid not being able to repair my own car. Especially with Mum and the kids stranded on the side of the road. Anyway he told me that it was a loose fuel injector connection of #4 cylinder. To this day I’m skeptical, but seeing as I’ve been out of the car trade for over twenty years. I think is plausible? Maybe something easy you could check? 2008 110 SVX Defender The Black Truck |
15th Jul 2012 11:03am |
Thanks for the suggestions.
The garage changed the fuel filter and a valve on the common rail of the diesel apparently and all should be fine now. |
18th Jul 2012 4:16pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10376 |
That's not a great Super Hero name
18th Jul 2012 4:19pm |
can anyone tell me how easy it is to replace the common rail valve.....does the ecu need to go through the learn process?
what about getting air in top the fuel system (hopefully not too much of an issue being the highest point) and can anyone tell the cost of said valve ? |
19th Jul 2012 7:56am |
The fuel rail itself has a fuel pressure (at the rail) sensor at the front, and a mechanical fuel pressure relief valve, which once activated needs to be renewed.
I suspect the OP is referring to the fuel metering valve/fuel quantity valve/volume control valve on the rear of the fuel pump. Sorry about all the names, but obviously more than one department worked on this and never decided on just one common term! The VCV is LR009837 and costs £99.84 + VAT RTS book time is 0.3, but probably more like 45 minutes to get everything out of the way to get to it. Yes, once the VCV is fitted, a calibration/pump learn needs doing. |
19th Jul 2012 10:22am |
