Home > Puma (Tdci) > is it me
Michaels Defender
United Kingdom 2013 Defender 110 Puma 2.2 ST Corris Grey
is it me
Is it me, but when I try to drive quickly in my defender, when I change up a gear, the revs always increase by 200-300 rpm, and this makes it very difficult to do a quick/smooth gear change, it maybe my driving style, but to stop the revs increaing I have to change gear very slowly, has any new puma owners experienced this, or is it a charicteristic, I don't want to go to my dealers and look a fool Embarassed JE Zulu 110 now sold
Carpathian 110 also sold
Defender 110 camper now in build
Post #802 1st Dec 2007 8:24pm
solmanic
Australia 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I think I know what you mean. When I took one for a test drive a few weeks ago I found it necessary to alter my gearchange technique a little and make sure I was off the accellerator a wee bit sooner when pushing the clutch in. I think the fact that it is a freer revving engine to the Td5 or Tdi makes it spin up when the clutch goes in if you're not right off the gas. 2007 Defender 110
1970 Alfa Romeo 1750GTV
Post #809 2nd Dec 2007 2:10am
solmanic
One other solution might be to get the clutch adjusted down a bit so it disengages a tad lower. I presume the clutch pedal mechanism is basically the same as the Td5 so probably one turn of the pedal adjustment nut ought to do it. 2007 Defender 110
Post #810 2nd Dec 2007 2:12am
AndrewS
I think there is a software up grade for this problem.
Post #811 2nd Dec 2007 5:04pm
Michaels Defender
Thanks, I'll have a word with my dealer, does your defender not suffer from the same ploblem Question JE Zulu 110 now sold
Post #817 3rd Dec 2007 5:12pm
AndrewS
No neither have this issue. I will ask 10forcash on the disco3 site for the info as he was the person that advised my of this issue in the first place.
Post #823 4th Dec 2007 2:02pm
Michaels Defender
Thanks Andrew, I'll hang on before going to the dealers JE Zulu 110 now sold
Post #826 4th Dec 2007 4:49pm
TJ101
Not noticed it with mine Rolling Eyes
I thing i have, which i presume it connected with the anti-stall, if you take the revs up to 1500 say, whilst stationary, and then hold, revs will drop back to tick-over in about 6 secs !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #830 5th Dec 2007 9:48am
CFB
Re: is it me
Mine started doing this today, also got jammed in reverse and wouldn't free for ages, oh and it is leaking like a good 'un in the passenger footwell Evil or Very Mad Andy
Post #865 9th Dec 2007 9:21pm
solmanic
Now that I have my vehicle I can confirm that it does blip the revs a couple of hundred RPM on each gearchange. I am still getting used to the feel, but so far I haven't worked out a technique for avoiding this altogether. If I try backing off the throttle sooner I usually get a bad, jerky gearchange so that's obviously not the solution. 2007 Defender 110
Post #871 10th Dec 2007 1:39am
Milligan
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
I've experienced the same thing and not been able to stop it happening however I try and drive when pushing hard. If anyone has had a fix applied etc., it would be good to have more detail before getting the dealer involved.
Post #878 10th Dec 2007 1:06pm
TJ101
Been using a 06 year 90 for the last few weeks, but jumped in the 07 yesterday for a trip to Torbay,, !! a total pleasure compered to the TD5
Maybe i have a good one, as no gear change issues, nice and smooth, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #880 10th Dec 2007 1:11pm
solmanic
I have actually noticed that with harder driving (changing at 3000RPM instead of 2500RPM) this doesn't seem to happen as much. 2007 Defender 110
Post #881 10th Dec 2007 1:19pm
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
I have just read this post and having owned my Puma TDCi for over 6 motnhs now and 12k miles I know exactly what people are talking about. It is quite hard to change gear smoothly with the new set up and I am convinced it is something to do with either the anti-stall or dual mass flywheel setup (that has been reported to fail in the Ford Transit). The technique I have predominently been using is not to touch the accelerator at all until the clutch is fully depressed for all gears other than 1st. This seems to work quite well for me. Another thing I have noticed is that you cannot start to accellerate slightly until the clutch is fully depressed when gearing down also as this causes a jolt in the tranmission.
Regards Rich
PS nice site especially with a dedicated Puma section.
Post #1007 3rd Jan 2008 5:17pm
AndrewS
This is a known fault and is a warranty fix via a software up-load, have a word with your dealers Thumbs Up
Post #1009 7th Jan 2008 12:24am
