![]() | Home > Maintenance & Modifications > 3.2TDCI 200BHP into a Defender 90, It can be done! |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 ![]() ![]() |
Bloody hell my Bowler speedo only just goes up that fast !!! If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
![]() Pete |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3664 ![]() ![]() ![]() |
Got excited for a mo but the video has been removed DOH!('
![]() I hope everyone is well and your land rovers make you happy |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 601 ![]() ![]() ![]() |
Hello from FullFatRR! First post here
![]() Could a 3.2 TDCI placed into a ~2004 TD5? 110 Station Wagon? The lack of power with the defender is the sole reason I don't own one, I'd happily replace my TD6 RR with a 3.2TDCI defender if possible.. I ask about doing this to an older TD5 as my budget for one would be ~16-18k max |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 ![]() ![]() ![]() |
Pete will probably let you know if is possible, but don't forget if you only have 16-18k budget alot of that would be swallowed up in the cost of an engine/gearbox. |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
It will fit but you will need to weld new engine mounts to the chassis also you would need to change the transfer box to a 1.2 version ?
Personally I would step up to a puma then convert it as its proven that the clocks work and so on Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
I Agree with Steve, I think the best starting Defender would be at least a MY2007 2.4TDCI Puma. Though it is possibile in the TD5 you would spend a lot more on parts that are already in the puma as standard to make it work.
Pete |
Chris Rogers Member Since: 28 Jun 2011 Location: Berkhamsted Posts: 28 ![]() ![]() |
I have the 200ps in my transit - its performance is amazing.
I'd kill for one in my defender! Dont think the budget will stretch though.... |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1852 ![]() ![]() ![]() |
Just saw it in the flesh at Eastnor - it looks soooo standard, you have to count the injector pipes to see its not.
First class installation. Keith |
Rob Member Since: 04 Sep 2012 Location: Brownhills Posts: 40 ![]() ![]() ![]() |
spoke to you at Eastnor Castle, very interesting, I was the fella in the grey fleece.....
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
Don't you mean step down to the Puma then convert it. TD5 to Puma to 3.2TDCI is like one step backwards then one set forwards ![]() The conversion to the 3.2 looks amazing a true factory looking fitment. I forgot to take any pictures though. |
I agree there but still need the right vehicle to start the build with
Totally agree, i've been contemplating moving to the Puma for this very reason but that would be a complete waste of a domain name. Unless I keep hold of the TD5 for weekends ![]() |
