Home > Maintenance & Modifications > 130 drop plate on a 110...yes/no? |
ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517 |
pic
Click image to enlarge |
2nd Jul 2012 4:00pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2638 |
(sorry can't answer for question)
Could you post the whole set up? i too have a defender with wheel on the back door and I'm a keen mountain biker (bike is on the back of car about 5 times a week) and looking at better alternatives to my current set up.. cheers |
2nd Jul 2012 4:03pm |
haven't got any better pic...
2nd Jul 2012 4:14pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10379 |
I have a pendle, the good thing about pendle is, I had the two bars that come out of the towbar bracket for a 4 bike rack, but I only have 2 bikes on, this gives me the clearance for the tyre, plus loads of room for 2 bikes without them all being stuffed together which avoids scratching...
So, to re-cap, you could ring pendle, ask for a 2 bike wheel support rack, but send the 2 bars for a 4 bike |
2nd Jul 2012 5:03pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
Don't think it would be any better
2nd Jul 2012 8:32pm |
yeah... hear that for functionality, but would the correct part be a better bodge
2nd Jul 2012 8:48pm |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 365 |
It would be stronger turning it around 180 degrees which is the way i've fitted mine as per the instructions. 130 crew cab
98 V8 Disco |
2nd Jul 2012 9:22pm |
noted...it is a lash up of two parts. the spacer is from a dixon bate product. i'll turn it around tomorrow and see how that works. still feels 'work in progress'...
i like proper OEM stuff (read normally more expensive ) |
2nd Jul 2012 10:06pm |
bump...
can someone with a 130 (lucky gits ) please upload a pic of the OEM drop plate and also measure the extension of the box.....please. |
3rd Jul 2012 7:33pm |
If you look in my gallery you will find some pics there
I think the measurement your after is 20cm. 130 crew cab 98 V8 Disco |
4th Jul 2012 8:04am |
There's not enough 130 owners on here
4th Jul 2012 8:06am |
RFT Member Since: 13 Nov 2010 Location: Cheshire Posts: 678 |
I'll go and measure mine right now 130 Puma HCPU with an Artica 240LR Demountable Camper
4th Jul 2012 10:23am |
Exactly 200mm 130 Puma HCPU with an Artica 240LR Demountable Camper
4th Jul 2012 10:25am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6604 |
I personally would like to see the tow ball bolts going all the way through to the drop plate, so the welds are not the part taking the full trailer load.
I presume that is what is in the tubes on a 130? 1988 90 Td5 NAS soft top 2015 D90 XS SW |
4th Jul 2012 10:29am |
