Home > Maintenance & Modifications > Genuine LR roof rack
shorty
South Africa 2009 Defender 90 Puma 2.4 XS CSW Chawton White
Hi guys, Ive got a genuine land rover roof rack on my 90. Part no LR004101. I was wondering if there is supposed to be or if there is available, a floor board / load deck. As it is at the moment there are large spaces in the form of cross bars. if there isnt anything available, what do you recommend I use as a floor board / load deck?
check http://landrover.tagworldwide.com/defender..._en_GB.php (page 2Cool Land Rover's don't leak oil, they simply mark their territory!
Post #11364 28th May 2009 3:08pm
shorty
see page 28 Land Rover's don't leak oil, they simply mark their territory!
Post #11365 28th May 2009 3:10pm
Eduardo
Shorty,
I use a marine 3/4" plywood on my roof rack with quite good results. Also I drilled 4 cm diam holes every 15 cm to reduce the weigth and to allow the airflow.
Cheers Eduardo
Post #11366 28th May 2009 3:49pm
fekete
Hi Shorty,
Over here i use a ifor williams trailer,
thay use a resin coated plywood platform on them they are only about 1/2" thick
and can withstand alot off weight and have an embossed grip pattern on the upper surface, and also quite light
im not sure if you could get something like that over there or ifor williams trade out there i no they are world wide? this would be the stuff id go for.
www.iwt.co.uk NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #11374 28th May 2009 6:07pm
