![]() | Home > Maintenance & Modifications > Genuine LR roof rack |
shorty Member Since: 31 Oct 2008 Location: Hillcrest, Kwa Zulu Natal Posts: 160 ![]() ![]() ![]() |
Hi guys, Ive got a genuine land rover roof rack on my 90. Part no LR004101. I was wondering if there is supposed to be or if there is available, a floor board / load deck. As it is at the moment there are large spaces in the form of cross bars. if there isnt anything available, what do you recommend I use as a floor board / load deck?
check http://landrover.tagworldwide.com/defender..._en_GB.php (page 2 ![]() |
see page 28 Land Rover's don't leak oil, they simply mark their territory!
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 ![]() ![]() ![]() |
Shorty,
I use a marine 3/4" plywood on my roof rack with quite good results. Also I drilled 4 cm diam holes every 15 cm to reduce the weigth and to allow the airflow. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Hi Shorty,
Over here i use a ifor williams trailer, thay use a resin coated plywood platform on them they are only about 1/2" thick and can withstand alot off weight and have an embossed grip pattern on the upper surface, and also quite light im not sure if you could get something like that over there or ifor williams trade out there i no they are world wide? this would be the stuff id go for. www.iwt.co.uk NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
