![]() | Home > Puma (Tdci) > Onboard compressor |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2443 ![]() ![]() ![]() |
Hi:
I got an ARB high output compressor (For ARB locker and to inflate tires as well) and I would like to fit it under the hood. NOt sure where yet. M Puma 110" SW ............................................................. Earth first. Other planets later |
philp Member Since: 21 Oct 2008 Location: surrey Posts: 22 ![]() ![]() |
I did no end of research on this topic and asked all the serious challenge event guys and ended up buying one of these... [/url]http://cgi.ebay.co.uk/T-max-double-pump-tyre-inflator-compressor---BA2663_W0QQitemZ290318054469QQcmdZViewItem[url]
And I am very impressed with it! |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5051 ![]() ![]() ![]() |
one_iota Member Since: 06 May 2008 Location: Sydney Posts: 99 ![]() ![]() ![]() |
There are some threads at AULRO on this topic:
http://www.aulro.com/afvb/90-110-130-defen...-puma.html This thread started here: http://www.aulro.com/afvb/90-110-130-defen...-puma.html Photos have failed but keep an eye out for developments Mahn '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
Thats the one,my link to it didn't work
![]() It's a good little compressor, it will pump up 4 x 285/75r16 mud tyres from flat in no time at all. You need to keep the engine running on the car it's being powered from ideally, as it uses a fair few amps. There are bigger and better compressors available, but for £75 plus a tenner delivery and the good reports from the "Landy nuts" I thought I would give one a try. I need to move mine from vehicle to vehicle so it is not permanently mounted, I'm sure someone on here has a good idea where to fit it. Or already has one fitted. |
Just place it with the battery and make some cables with some proper connectors (name escapes me...but the grey ones used on jump leads or winches)
Then fit 2 connectors on the cars you want to use it to...job done Mike |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
I have plumbed a 2.5 gallon tank into the the compressor that the warn powerplant winch has inbuilt
RgrBox Member Since: 04 Jun 2009 Location: St-Cergue, Switzerland Posts: 111 ![]() ![]() ![]() |
This is also one of my next buys.. I need one, after this last weekend, when my wife's Subaru Impressa's rear tire deflated. I walked down to where she parked it, and then looked inside here trunk box with all of the kit I put inside for her. No can of tire inflation that I had put inside??? I then walked to a garage, and their air compressor wasn't working.. I then walked to the local store to see if I could find something.. nothing.. I found a guy with a mini, and I mean mini compressor. I half way aired up the tire and slowly drove up to my place 1 km away. I changed the tires to Summer tires, and then drove down the mountain to the next station.. I plug in the hose to the tire, and before I could stop it, half of the air was gone. Their compressor was broken.. I then got into the car and drove slowly to the next station where I aired up the tires, and drove home.. I decided then and there, i needed a compressor myself.
RB 2008 110 2.4 tdci csw Landrovers of Switzerland Club member |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 ![]() ![]() |
Anderson connectors? http://www.torberry.co.uk/shop/index.php ![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
Those are they Mike |
