Home > Puma (Tdci) > Onboard compressor
bustduster
Onboard compressor
Has anyone had an onboard compressor fitted to a Puma? Would appreciate any comments on suitable places it could be fitted and recommendations on which manufacturer.
Post #11209 22nd May 2009 3:28pm
MK
Hi:
I got an ARB high output compressor (For ARB locker and to inflate tires as well) and I would like to fit it under the hood. NOt sure where yet.
M Puma 110" SW
Post #11212 22nd May 2009 7:13pm
philp
2008 Defender 90 Puma 2.4 HT Tonga Green
I did no end of research on this topic and asked all the serious challenge event guys and ended up buying one of these... [/url]http://cgi.ebay.co.uk/T-max-double-pump-tyre-inflator-compressor---BA2663_W0QQitemZ290318054469QQcmdZViewItem[url]
And I am very impressed with it!
Post #11214 22nd May 2009 8:18pm
mse
Post #11226 23rd May 2009 8:27am
one_iota
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
There are some threads at AULRO on this topic:
http://www.aulro.com/afvb/90-110-130-defen...-puma.html
This thread started here:
Photos have failed but keep an eye out for developments Mahn
'08 Defender 110
ex '95 Disco 300 Tdi
www.aulro.com
Post #11235 23rd May 2009 10:16am
philp
Thats the one,my link to it didn't work Embarassed
It's a good little compressor, it will pump up 4 x 285/75r16 mud tyres from flat in no time at all.
You need to keep the engine running on the car it's being powered from ideally, as it uses a fair few amps.
There are bigger and better compressors available, but for £75 plus a tenner delivery and the good reports from the "Landy nuts" I thought I would give one a try.
I need to move mine from vehicle to vehicle so it is not permanently mounted, I'm sure someone on here has a good idea where to fit it.
Or already has one fitted.
Post #11236 23rd May 2009 10:17am
mse
Just place it with the battery and make some cables with some proper connectors (name escapes me...but the grey ones used on jump leads or winches)
Then fit 2 connectors on the cars you want to use it to...job done Mike
Post #11238 23rd May 2009 10:24am
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
I have plumbed a 2.5 gallon tank into the the compressor that the warn powerplant winch has inbuilt
Post #11244 23rd May 2009 2:54pm
RgrBox
United States 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
This is also one of my next buys.. I need one, after this last weekend, when my wife's Subaru Impressa's rear tire deflated. I walked down to where she parked it, and then looked inside here trunk box with all of the kit I put inside for her. No can of tire inflation that I had put inside??? I then walked to a garage, and their air compressor wasn't working.. I then walked to the local store to see if I could find something.. nothing.. I found a guy with a mini, and I mean mini compressor. I half way aired up the tire and slowly drove up to my place 1 km away. I changed the tires to Summer tires, and then drove down the mountain to the next station.. I plug in the hose to the tire, and before I could stop it, half of the air was gone. Their compressor was broken.. I then got into the car and drove slowly to the next station where I aired up the tires, and drove home.. I decided then and there, i needed a compressor myself.
RB 2008 110 2.4 tdci csw
Landrovers of Switzerland Club member
Post #11523 4th Jun 2009 10:15am
NoDo$h
Anderson connectors?
http://www.torberry.co.uk/shop/index.php
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #11537 4th Jun 2009 3:21pm
mse
Those are they Mike
Post #11538 4th Jun 2009 3:32pm
