Home > Puma (Tdci) > plastic engine cover
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
Hi
I see the back of my plastic engine cover is loose (i can lift it up a bit - it is bolted down at the front end). Is this correct?
And so is the cover that covers the "air cooler outlet valve" (i think that's what it is). I've pushed this back into place, but the main top cover is still loose at the back.
Comments?
Cheers www.ralton.co.za
Post #148878 6th Jun 2012 11:51am
Naks
Re: plastic engine cover
Don't have the landy handy, but I'm sure it's not meant to be loose? --
Post #148886 6th Jun 2012 12:12pm
Caterham
are we talking air filter cover?
clips down where you can see it but undert the wing top the box top / cover slides into 2 retainers - easily fitted incorrectly and therefore a little loose.
hope this helps. not sure about engine cover tho.
Post #148887 6th Jun 2012 12:22pm
ralton
Hi - see pic.
The orange arrow points to the main top cover that isn't fastened at the back end (the end where the arrow originates).
The yellow arrow is the cover that i've "clipped (not very firmly)" into place.
Thanks
 www.ralton.co.za
Post #148889 6th Jun 2012 12:38pm
marklockett2103
mine seems tight. good for warming up heinz big soup on a long journey. fits in there perfectly, only LR would think to fit a food warmer in the engine bay... Wink
Post #149133 8th Jun 2012 8:02am
