Home > Puma (Tdci) > plastic engine cover |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 |
Hi
I see the back of my plastic engine cover is loose (i can lift it up a bit - it is bolted down at the front end). Is this correct? And so is the cover that covers the "air cooler outlet valve" (i think that's what it is). I've pushed this back into place, but the main top cover is still loose at the back. Comments? Cheers www.ralton.co.za |
6th Jun 2012 11:51am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2635 |
Don't have the landy handy, but I'm sure it's not meant to be loose? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
6th Jun 2012 12:12pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
are we talking air filter cover?
clips down where you can see it but undert the wing top the box top / cover slides into 2 retainers - easily fitted incorrectly and therefore a little loose. hope this helps. not sure about engine cover tho. |
6th Jun 2012 12:22pm |
Hi - see pic.
The orange arrow points to the main top cover that isn't fastened at the back end (the end where the arrow originates). The yellow arrow is the cover that i've "clipped (not very firmly)" into place. Thanks Click image to enlarge www.ralton.co.za |
6th Jun 2012 12:38pm |
