Home > Maintenance & Modifications > Help with tyre size please |
Defenderst Member Since: 02 Apr 2012 Location: Somerset Posts: 39 |
Hi.
Would the following fit my Defender 300tdi 90 which has just a 2" lift? rolled edge 10x15 mach 5's fitted with cooper stt 33, 12.50, 15 Many thanks for quick responses. |
16th May 2012 5:39pm |
Yes,
Same size Fekete's got and same lift. Have a look in his gallery. Stick out a bit though as the Mach 5s have a 40mm offset. I too have the same wheels but have gone for 32.5 x 11.5 x 15, pictures in my gallery too. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
16th May 2012 5:56pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8006 |
they will fit, you may get some rubbing on the arches on full articulation if the truck is heavily loaded in my experience. Cheers
16th May 2012 8:02pm |
