Home > Maintenance & Modifications > Help with tyre size please
Defenderst
1994 Defender 90 300 Tdi ST Bonatti Grey
Hi.
Would the following fit my Defender 300tdi 90 which has just a 2" lift?
rolled edge 10x15 mach 5's fitted with cooper stt 33, 12.50, 15
Many thanks for quick responses.
Post #145378 16th May 2012 5:39pm
K9F
Yes,
Same size Fekete's got and same lift. Have a look in his gallery. Stick out a bit though as the Mach 5s have a 40mm offset. I too have the same wheels but have gone for 32.5 x 11.5 x 15, pictures in my gallery too. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #145385 16th May 2012 5:56pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Yes they will fit without any lift so if you have a 2" lift...no problem Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #145388 16th May 2012 6:08pm
jst
they will fit, you may get some rubbing on the arches on full articulation if the truck is heavily loaded in my experience. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #145415 16th May 2012 8:02pm
