![]() | Home > Td5 > TD5 transfer problem |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Hi there!
A good friend has broken the transfer of his beloved TD5 (LT230 43D transfer case) and he need to replace it. Some questions for the specialists: Are all the housing of the LT230" D type" equals and only changes the pinions inside or have some differences that not allow to exchange it (Housing/pinions)? Can he install a LT230 34D from a Discovery V8 instead? Thanks in advance Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Big Steve,
The current Defender's transfer is a 1.41 (43D), The Discovery V8 is also 1.41 (34D) Can he use the 34D in the TD5 without major modifications? Or, Can he use any "D" housing with a 43D set of pinions/shafts,etc ? Thanks Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 160 ![]() ![]() ![]() |
You need to swap over the high / low detect switch housing from the original box. Other then that, they are the same. My t-box was also from a disco v8 which is 10 yrs older than my 10 yr old td5. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
