Home > Puma (Tdci) > trailer wiring harness
Page 3 of 3 <123
Merlin
Looking at the diagram that LandRoverAnorak has posted above, it says that the green wire, pin 4 on the 12S, is a continuous live feed. This is different to the fridge feed which is on pin 6 (the red wire). I'm using the towing kit from LR with their electrics.
Merlin
Post #412628 31st Mar 2015 9:47am
Simon.pl
Poland 2007 Defender 110 Puma 2.4 HT Keswick Green
Guys
I'm refreshing my harness and found a strange connection: the purple cable, that should be permanent 12V as I understand from the Defender Wiring, is welded into RedYellow cable with the diode (what is it for?).
Should it be like this, or it's "customized"?
Also - what is this GreenBrown cable with the black connector at the end for? It is written in the Defender Wiring it goes to Diode, but there is no diode at the end.
Post #643656 13th Aug 2017 5:13pm
Page 3 of 3 <123
