Home > Puma (Tdci) > Cruise Control
Page 4 of 4 <1234
slick75
Wales 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Google Conrad Anderson some good kit had cruise control from him on older car very good company Thumbs Up 08 def 90 ht stornaway grey
Post #125164 19th Feb 2012 1:54pm
T1G UP
Lorryman100 wrote:
Contacted Howard-May for a quote to fit my puma, here is the reply:
http://www.howard-may.co.uk/4555.html
Hello Brian, and thank you for your enquiry. Your Defender is drive-by-wire, so the solid-state cruise control is the one we use. The fitting is mobile, and your quote is set out below. Please find attached pictures of the standard and upgrade command modules. If you require any further information, please get back to us. The cruise control is guaranteed for 1 year.
Solid-State cruise control (with stalk command module) £335.00
Clutch switch £15.00
Fitting (At your location) £155.00
Optional 2-memory command module Add £10.00
Regards.
Steve Jones (Howard-May)
Wonder how easy it would be to fit myself? Could then put the £155 towards getting a X-DeFlex - Unlockable Anti Roll Bar!!!! Wink
i had the same thought! TJ fitted his own so can't be that hard. I want a front and rear x deflex when they make a set
Post #125220 19th Feb 2012 6:01pm
TJ101
T1G UP wrote:
] i had the same thought! TJ fitted his own so can't be that hard. I want a front and rear x deflex when they make a set
Normally a easy fit
But in your case Marcus,, I would suggest you get a grown up to fit you a cruise kit
The X Flex for the rear is already available,, but very much doubt a rear ARB disconnect will be done by Si California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #125272 19th Feb 2012 8:40pm
T1G UP
TJ101 wrote:
Normally a easy fit
wasn't a dig! I want one but a £500 it can wait.
Ah well...another £250 saved!
Post #125279 19th Feb 2012 8:44pm
chinnus
2001 Defender 90 Td5 ST Coniston Green
hi all, does anyone have the installation manual supplied by howard may?
Many thanks
Post #219449 16th Mar 2013 12:44am
Page 4 of 4 <1234
