![]() | Home > Td5 > jumpy/shuddering 1st gear |
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897 ![]() ![]() ![]() |
Sounds plausible to me Geoff 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy ![]() |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
I would not panic at the moment, if you were playing on the plain last weekend, I would think you have mud and mess in places you can't see. Give it a little time to self heal
![]() I would start with pumping some grease in the uj's Andy |
Geoff 90 Member Since: 21 Jan 2012 Location: Wexford/Dublin Posts: 26 ![]() |
Cheers for the advice. I'll give it a good power wash underneath today and I'll grease everything I can see after work tomorrow worth a shot.
Stoo Member Since: 20 Aug 2009 Location: Maidstone, Kent Posts: 37 ![]() ![]() |
Mine has had the same issue for a couple of years now, and I assume it is related to the DMF. Not a big issue I guess until it actually goes wrong, but it does make pulling away smoothly difficult.
I'm waiting until the clutch finally gives up the ghost (probably not much longer) and will change the DMF at the same time. Then again your problem might be something totally different - but it does sound similar! Stoo |
robpenrose Member Since: 15 Jan 2011 Location: Hampshire or Cornwall Posts: 338 ![]() ![]() |
Mine is very jittery when I first start driving it in the morning. It seems to sort itself out after about 30mins of driving.
It's been like it for a couple of years, very annoying... Current:D4 HSE Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
When it first started happening over the weekend one of the lads suggested that it might be a"wound up" diff, do you think that it could be this?
cheers Geoff |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
Does it behave the same even when up to temp?
yeah it seems to alright. Just doesn't happen all the time i take off which is weird. Would it make a difference if it only happened when cold or only when warm?
When cold the various fluids, oils and components will be cold obviously and will be thicker and after warming up everything will heat up and become smoother and more fluid so to speak. I wouldn't worry if I was you as some times they have the odd thing happen but goes again. Mine like others often has the amber dash warning light come up and you tend to think what's wrong but in reality after a couple of trips it turns off by it's self and there was nothing wrong all the same. 1st gear is a little different from the rest mainly due to it being such a low gear so I always treat it with respect I do use it all the time but at low speeds. Often when pulling up pulling up in 2nd and only pulling off in 1st. depends on situation though. |
Gave the defender a good power hose underneath yesterday and greased the ul's this morning so will see how that goes worth a shot anyways.
Cheers Geoff |
