![]() | Home > Technical > Clicking Sound ???? |
You could put some copperslip between the pads and anti rattle shims 2.4 90 XS
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 ![]() ![]() ![]() |
Only with stones stuck in the tyre tread. 130 crew cab
98 V8 Disco |
Bullet Member Since: 21 Apr 2009 Location: Benoni Posts: 7 ![]() ![]() ![]() |
An interesting reply from landydoctor on the landrover net:
![]() "The cheaper pads have bigger slotted holes in them. The slots allow the pad to rotate around the disc slightly (about 3 or 4mm) when they hit the retaining pins you hear a click. you'll also hear the same click if you go over bumps." |
