Home > Technical > Clicking Sound ????
Bullet
South Africa 2003 Defender 110 Td5 DCPU Rimini Red
Clicking Sound ????
Since having my front brake pads replaced Very Happy , I've been hearing a clicking sound comming from the right front tyre(brake unit), every so often Question . Had it back for a check up but everything appears to be ok Big Cry ! Any of you guys had a similar problem / any thoughts on this Neutral
Post #10664 11th May 2009 1:07pm
Grockle
You could put some copperslip between the pads and anti rattle shims 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #10672 11th May 2009 2:18pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
Only with stones stuck in the tyre tread. 130 crew cab
98 V8 Disco
Post #10676 11th May 2009 4:53pm
Bullet
An interesting reply from landydoctor on the landrover net: Thumbs Up
"The cheaper pads have bigger slotted holes in them. The slots allow the pad to rotate around the disc slightly (about 3 or 4mm) when they hit the retaining pins you hear a click. you'll also hear the same click if you go over bumps."
Post #10871 14th May 2009 5:38am
